Old 01-13-2020, 06:11 PM
greghughespdx's Avatar
Default RV-12iS Service Bulletin - SB 19-08-06 - AV-60000 and AV-60009 Recall
Van's Aircraft has published a new Service Bulletin (SB 19-08-06) that describes steps to be taken on certain RV-12iS aircraft, in order to capture detailed photographs of two electronic components and then send the photos to Van's for review.
In limited cases, solder on AV-60000 and AV-60009 electronics modules may not have been heated sufficiently to ensure a strong enough solder joint. In those cases, there exists the potential for intermittent electronic issues.
Photographic examination of the components will allow Van's staff to visually determine whether or not the module's solder joints are properly formed and acceptable. In the event the soldering of a module in the field is determined to be insufficient, the module will need to be shipped to Van's for service. In this case, Van's will pay the shipping costs to return the defective module to Van's, and to deliver the repaired/replacement module to the customer.
When taking the photographs, please ensure that 1) plenty of light illuminates the subject - a flashlight or similar source may be used, and that 2) the photos are close-in, sharp and taken in high resolution. Most modern smartphones should be able to produce acceptable images.
Note that Van's has identified and confirmed the root cause of this issue and has made changes to its manufacturing processes as a result.
Greg Hughes - Van's Aircraft
Building RV-8A since Sept 2014
Aurora, OR (EAA Chapter 105)
Old 01-13-2020, 08:35 PM
Crafting N112DR's Avatar
Crafting N112DR Crafting N112DR is offline
Default revision needed
"Take clear, in focus, well lighted, pictures of the 3 locations noted in Figure 3 on the AV- 60000 and the location in Figure 7 on the AV-60009."
Note: there is no figure 7
There is however a figure 1 after figure 6. So there are two figure 1.
I'm sure the 2nd figure 1 is just a typo but might need a revision for clarification
___________
David Rohrlick
PPSEL, A&P
N112DR (RV-12iS) (SOLD)
Airworthiness signed off by the FAA 1/23/2020
First Flight on 3/14/2020
Phase I Finished on 5/7/2020
Serial#12-0864
https://youtube.com/c/CraftingN112DR
VAF donation made for 2021
Old 01-14-2020, 09:56 AM
Good catch - thank you! Interestingly the PDF export regenerated the figure numbers incorrectly, we may have found a bug.
An updated and correct PDF has been uploaded to replace the one with the incorrect figure number. Again, thanks!
