Old 01-13-2020, 01:37 PM
74-07 74-07 is online now
Default Angle Valve Rocker Arm Shaft (whew)
Replaced a pushrod tube yesterday after new seals failed to stop leak. We discovered that the pushrod shroud (tube) was out-of-round on the end that inserts into the crankcase side. I dreaded the struggle to get the rocker arm shaft reinstalled as it requires a little pressure on the rocker arm while jiggling the rocker arm shaft while trying to keep everything in alignment. Yes, I did have both valves relaxed, the tappets bled down and the moon in the seventh house but, as always, I just needed about a thousandth more clearance to slide the shaft through. After trying everything for a couple of hours last evening, I quit and went home. I called an old sage IA on the way home to ask if he could come lend a hand this morning. He told me that it was an easy one man job! He then told me his trick.
Go to Lowes and by a $7, 3 ft. Length of 1x1 angle iron
Drill a 1/4 inch hole, about one inch from the end.
Place the angle up to the cylinder head and put one of the botton valve cover
screws through the hole and just snug it up. The angle will now swing out of the way and allow you to position the rocker arm and spacer.
Next, swing the angle over and onto the rocker arm and apply just a litlle pressure on the angle with one hand while pushing on the shaft with the other. Jiggle, jiggle.
Bamm! It slid right in!!!!!!
Took longer to drill the hole than to put the rocker arm shaft back in. As you can see, the angle is too long as I didn't cut it but after seeing this today, we cut it and now a buddy has a tool also.
Ok, now I'm waiting for all of the experts to tell me every reason this is foolish, dangerous, too expensive, against FAA regulations and the real reason Jeffrey Epstein didn't kill himself.
Old 01-13-2020, 01:41 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Thanks for the tip. Here's your pic:
Carl N.
Arlington, WA (KAWO)
RV-8, 790 Tach Hours
(Pic 1),(Pic 2)
- Out with the Old, In with the New
(Pic)
RV-8, 1938 Tach Hours (Pic 1),(Pic 2) - Sold
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 01-13-2020, 01:44 PM
Thanks for the help! Still figuring the photo thing out.
Old 01-13-2020, 02:48 PM
Walt's Avatar
Walt Walt is offline
This is not required if the lifters are bled all the way down. If I remember correctly the clearance should be 0.028-0.080".
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
