Old 05-18-2007, 02:30 PM
N941WR's Avatar
N941WR N941WR is offline
Default New fuel for 21st century -- aluminum pellets?
Just another use for our RV's once we are User Fee'ed out of the sky.
By Julie Steenhuysen
Reuters
1 hour, 30 minutes ago
CHICAGO (Reuters) - Pellets made out of aluminum and gallium can produce pure hydrogen when water is poured on them, offering a possible alternative to gasoline-powered engines, U.S. scientists say.
Hydrogen is seen as the ultimate in clean fuels, especially for powering cars, because it emits only water when burned. U.S. President George W. Bush has proclaimed hydrogen to be the fuel of the future, but researchers have not yet found the most efficient way to produce and store hydrogen.
The metal compound pellets may offer a way, said Jerry Woodall, an engineering professor at Purdue University in Indiana who invented the system.
"The hydrogen is generated on demand, so you only produce as much as you need when you need it," Woodall said in a statement. He said the hydrogen would not have to be stored or transported, taking care of two stumbling blocks to generating hydrogen.
For now, the Purdue scientists think the system could be used for smaller engines like lawn mowers and chain saws. But they think it would work for cars and trucks as well, either as a replacement for gasoline or as a means of powering hydrogen fuel cells.
"It is one of the more feasible ideas out there," Jay Gore, an engineering professor and interim director of the Energy Center at Purdue's Discovery Park, said in a telephone interview on Thursday. "It's a very simple idea but had not been done before."
On its own, aluminum will not react with water because it forms a protective skin when exposed to oxygen. Adding gallium keeps the film from forming, allowing the aluminum to react with oxygen in the water.
This reaction splits the oxygen and hydrogen contained in water, releasing hydrogen in the process.
"I was cleaning a crucible containing liquid alloys of gallium and aluminum," Woodall said. "When I added water to this alloy -- talk about a discovery -- there was a violent poof."
What is left over is aluminum oxide and gallium. In the engine, the byproduct of burning hydrogen is water.
"No toxic fumes are produced," Woodall said.
"When and if fuel cells become economically viable, our method would compete with gasoline at $3 per gallon even if aluminum costs more than a dollar per pound."
Recycling the aluminum oxide byproduct and developing a lower grade of gallium could bring down costs, making the system more affordable, Woodall said.
The Purdue Research Foundation holds title to the primary patent, which has been filed with the U.S. Patent and Trademark Office. An Indiana startup company, AlGalCo LLC., has received a license for the exclusive right to commercialize the process.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-18-2007, 02:40 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
I read this earlier today. Very cool. Ahh fill 'er up with 6061T6!
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 05-18-2007, 04:49 PM
Ralph Kramden Ralph Kramden is offline
So what's it take to return the aluminum oxide / gallium back to a usable state?
And whatever happened to the process of using a borax or laundry detergent type substance to produce hydrogen? It was in the news a year or so ago...
Old 05-18-2007, 06:48 PM
lucky333's Avatar
lucky333 lucky333 is offline
Default Uhhhh...
Has anyone considered the energy it takes to actually MAKE the Al pellets? Nice idea but probably doesn't fit the whole energy budget thing.. Ralph Nader once called Al 'solid electricity' which is a pretty accurate description. And electricity is 'spensive..
Of course, if we recycled all of the beer cans at OSH....
J
John Oldenkamp
RV-7A project for sale
VAF Paid 2018
Old 05-18-2007, 07:59 PM
Ted Johns Ted Johns is offline
Default It's just a battery
So instead of lead-acid, you have aluminum-gallium-water. Cool, it might be lighter, i.e. more energy dense than lead-acid. But, it's still just a battery, not a primary energy source.
Old 05-18-2007, 11:25 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Originally Posted by Ralph Kramden
So what's it take to return the aluminum oxide / gallium back to a usable state????
To quote Robert Heinlein,
"TANSTAAFL"
Mike
Old 05-19-2007, 06:42 AM
Captain_John's Avatar
Mike,
Got it now!
It took a little looking up, but now I am up to speed!
True dat!
CJ
The experiment works!
Old 05-19-2007, 07:43 PM
airguy's Avatar
airguy airguy is offline
Problem - the weight of the aluminum/gallium mix will FAR exceed the weight of the current fuel we burn, in order to produce enough hydrogen to fuel any decent amount of power, not to mention the high amount of heat produced during the reaction.
TANSTAAFL indeed.
