Old 01-08-2020, 03:09 PM
mtnflyr mtnflyr is offline
Default How to fix RV-6A that needs large changes in elevator trim
I bought a 6A some time ago and need some help understanding what changes I can make to it to reduce the need for large changes in elevator trim.
On final, I can't trim out the stick force with full nose-up trim. It's manageable, but I like to trim to a stable hands-off state and I can't do that today.
For takeoff, flaps up, the airplane rotates nicely with a fair amount of nose-up trim, and I have to trim aggressively down as the airplane accelerates. This isn't a huge deal for a normal takeoff but makes the airplane a handful on a go-around.
The trim movements I need to go from 80 mph to 120 mph are significant - much more than I'd like to have to do.
What should I check? CG comes to mind - I'm guessing that the airplane has a CG that is further forward than optimum. Would forward CG cause the need to trim more than a properly balanced aircraft? I don't want to start messing with stuff without understanding the aerodynamics causing the behavior I'm seeing.
The set up: Lycoming O-360 with a Hartzell constant speed prop. Battery on the aft side of the firewall.
Old 01-08-2020, 03:39 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
From your post, it sounds like you are a new (non-builder) owner. If so, hope the following helps:
1. Get a set of plans/drawings from Van's that will describe/show how the trim system works and is adjusted. All RV owners, builder or not, should have these plans and drawings. You will need them for basic maintenance and troubleshooting (and just to understand your plane) in the future. Can be found here:
https://shop.vansaircraft.com/cgi-bi...oduct=fd_plans
2. Assuming manual trim on a 6, you adjust the trim back where the trim cable comes out of the bottom of the elevator. There is a double set of nuts on the trim cable that can adjust travel both up and down where it connects to a bracket on the inspection cover plate. Generally speaking, a neutral trim tab should occur when the trim knob in the cockpit has roughly half of its turnability in each direction, but the actually amount of needed travel up and down in degrees is probably listed in the 6's manual and/or drawings. From your description it sounds like you need to make this adjustment.
Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2022
Old 01-08-2020, 03:41 PM
D Weisgerber's Avatar
D Weisgerber D Weisgerber is offline
The first thing I would do is a weight and balance. You might want to check the angle of incidence of the horizontal stabilizer also.
Dave Weisgerber
RV8 N848DW. Ser#83830 done.
James Cowl
DAR inspection on 7-23-2021
First flight on 7-25-2021
Phase 2 on 9-3-2021
Old 01-08-2020, 04:20 PM
Bavafa Bavafa is offline
Plus one for these two items to check. RVs require a fair amount of pitch trim when flaps are used but if they are rigged correctly or there isn't a big issue with CG, all well within trim range. My RV7A needed trim but even with nearly full weight in the baggage, we never ran out of trim.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - in progress
Dues paid
Old 01-08-2020, 04:33 PM
merlin3 merlin3 is offline
I only trim based on different loads. I can takeoff, trim and never touch the trim again for rest of the flight. Something has to be majorly wrong.
Justin
Rv-6, o360, whirlwind cs prop, old paint and panel
Rv-4,o-320,prince prop, mgl avionics screens - sold
Old 01-08-2020, 05:35 PM
RVDan RVDan is offline
I second this. Even if the trim was misrigged, it should be much more sensitive. But I?d start with the basics, weight and balance. An aft CG will require excessive elevator, thus excessive trim. W&B is a place many home builders come up short.
If loaded CG is within limits, the next problem area could be horizontal angle of incidence. Need the plans set for that.
Good luck.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Retired Aerospace Engineer and A&P/IA
Old 01-08-2020, 05:46 PM
Dan 57's Avatar
Dan 57 Dan 57 is offline
yep, all good answers above.
Talking incidence, also check the wings incidence, then the HS incidence. The relation between those 2 is important.
Life's short... Enjoy!
http://www.aerofun.ch
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
Old 01-08-2020, 05:49 PM
That isn't my experience. Solo, my airplane requires full nose up trim to hold 75 knots with the flaps all the way down and power at idle. Effectively, this is my landing configuration. With a farther aft CG, the need for full up trim goes away. At the same (solo) CG and weight, trim is roughly neutral during full power takeoff and climb (assuming no flaps).
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
rocketman1988 rocketman1988 is offline
Default hmmm...
So you are saying that you do not trim for different speeds? Highly unlikely...
Bob
Aerospace Engineer '88
RV-10
N464RL
Dues+ Paid 2020,...Thanks DR+
Old 01-08-2020, 06:03 PM
scsmith scsmith is offline
Unless his c.g. is very far aft. At the true neutral point, there would be no change in elevator position with speed. And if the horizontal tail incidence was chosen just right, there would be no change in hinge moment either.
For the OP, assuming your trim system is mechanically adjusted so that you are actually getting full tab deflection, then your observations strongly suggest you are very nose heavy.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
