Old 01-08-2020, 04:07 AM
rvflyerUk rvflyerUk is offline
Default Inverted Oil Installation
Just wondering if anyone can offer a suggestion or two;
I'm installing christen inverted oil into an Rv7 that has an XP-IO360 with cold air induction.
Issues are that the Vans brackets aren't usable because the inverted oil return line goes to a union to the front of the sump to the right of the starter, preventing the Vans bracket being installed.
Although I have seen the mixture run under the cold air induction spider and above the exhaust, the risk of it being cooked by the exhaust is significant.
A heat deflector attached to the exhaust would probably be insufficient.
Just looking for suggestions on a solution.
Another issue is obtaining an alternate mixture lever from Precisiion Airmotive is proving difficult - they sell it but only through their distributors, but none have any!! I'm also very surprised at the poor support offered by Superior.
Old 01-08-2020, 04:51 AM
KatanaPilot KatanaPilot is offline
We had to make our own brackets. We have a Titan/ECI IO-360 with a Superior cold air sump and full Christen inverted oil system. We have an Airflow Performance (Bendix) servo, not Precision.
Here are a couple of pictures. Hope it helps.
http://
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2
RV-10 under construction at Synergy Air South
Old 01-08-2020, 06:55 AM
Default Krea Ellis - reply
Hi Krea,
Many thanks for making the effort to help; However, I have the crossover exhaust from Vetterman which means it will likely cook my mixture cable.
The devil seems to be in the detail of my specific installation. I am about to give up on having inverted oil!
Old 01-08-2020, 07:13 AM
Default Oil return line
Hi Krea,
Last question, I looked at you r photos, where does your oil return line enter the sump?
Old 01-08-2020, 07:59 AM
vlittle's Avatar
vlittle vlittle is offline
In addition to a heat shield, I used 1.4" ID fire sleeve on my mixture and throttle cables. Spruce has it.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
