Go Back   VAF Forums > Avionics / Interiors / Fiberglass > COMM
  #11
Old 01-07-2020, 09:28 PM
fl-mike's Avatar
fl-mike fl-mike is offline
This switch is for flaps, but your com could use the same.
Mike W
Venice, FL
N164WM
Old 01-07-2020, 09:38 PM
rocketbob's Avatar
I just wired two radios in a RV6 with a DPDT PTT select switch, which just switches the PTT lines for both radios. No audio panel. This same thing could be implemented with one momentary DPDT switch. No need to switch the mic lines, as the mic audio is split from the intercom going to both radios. Both radios should have transmit inhibit lines tied to each other which reduces the sensitivity of the non-transmitting radio while the other is transmitting.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
