The Electroair system uses MAP to control the advance curve. A turbocharged aircraft will have higher MAP and so the ignition curve is not as advanced.
In my experience, retarding (i.e. not advancing) the timing will reduce the run-up RPM.
I have a switch on my panel that turns off the timing advance to the Electroair, and the RPM drop is quite apparent (no recorded values and I am down for my annual).
I also monitor timing advance on a voltage input on the SkyView EMS.
V
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
