01-01-2020, 08:16 PM
GAP 26/Static system question
I just purchased a Garmin GAP 26 Pitot/AOA probe. Is there an official position/consensus regarding the static source for the probe; i.e. is the probe static source dedicated for the G3 only?
Asked another way: Can the "typical" static source system be eliminated; AOA static source be utilized for other instruments?
Forgive me if this has been asked/answered before.
01-01-2020, 08:46 PM
Most people just use the Vans static source for altimeter, airspeed, etc., and AOA data. No separate static source just for AOA.
01-02-2020, 01:47 PM
GAP 26 Connections
The GAP 26 has a connection for the Pitot and AOA inputs on the GSU 25. There is no static connection from the Pitot tube. You will need to run a dedicated static line from the GSU 25 to a suitable location on the airframe for a static port.
Justin
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
01-02-2020, 01:55 PM
Justin
1- Will your GARMIN G3X AOA GAP 26 HEATED PITOT TUBE Model# 010-01074-10 work with the Dynon FlightDeck-180 for AirSpeed and AOA indications? https://www.aircraftspruce.com/catal...h_11-11449.php
2- Why do you have that one without a controller and another with a controller?
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
01-02-2020, 03:04 PM
GAP 26
We have not done any testing with that equipment and our Pitot tube, I am not sure of the compatibility between the two.
Steve provided a nice explanation of the differences between the regulated and unregulated versions of this unit in this post: http://www.vansairforce.com/communit...82&postcount=3
Please let us know if you have any other questions.
Justin
Garmin G3X Support
g3xpert@garmin.com
01-02-2020, 04:29 PM
Justin
Very informative, thanks ! It also clears up how the regulated pitot tube warms up when turned on, even on the hottest days. A pilot on another forum is saying it might be better to just turn on the pitot tube every time you fly regardless of temps because after a few years flying with his turned mostly off the water has started to corrode the inside of his pitot tube, even with clear drains.
Dynon told me this morning that their pitot tube turns on below 45 degrees. That makes me thing that with regular summer flying even with the switch ON it wouldn't evaporate the water in the tube. Just another thing I'm going to have to get clarification from Dynon on.
So does Garmin sell just the heating element for field replacement or do I need to buy an entire new pitot tube if the heater goes bad?
