Old 05-21-2007, 10:10 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
The original poster has a 6A which I also have and with a 76 inch prop, I think I have about 7.5 inches of ground clearance with nobody aboard and have had no issues with picking up rocks. That being said, my airplane has never seen grass strips. The 7A has a much more level ground stance and it seems as though the main gear is longer to me which might give you a bit less prop clearance than on the 6A.
Don't think a 74 inch is anything to worry about on a 6A.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 05-22-2007, 05:25 AM
RV6_flyer's Avatar
Originally Posted by rv6ehguy
Can anyone help me? I am in a position to purchase a Hartzell constant speed prop at a bargain price. The model is C2YK-1BF / F7666A-2. This prop is 74" in diameter and is 2 inches longer than most props going on a RV6A. I would like to put this prop on a Lycoming clone IO -360 180 hp engine. Can any one see any problems with this combonation? Would I be better off reducing the prop by 2 inches? Any advice would be appreciated. Cheers.
I know of one RV-6 that had a 74 inch prop. The builder sold it after flying around 200 hours with no problems. The new owner was doing transition training (with an RV pilot / CFI) in it and hit the prop on a wheel landing during the first two hours.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
