Old 12-27-2019, 10:11 PM
lr172 lr172 is offline
Default Another Successful First Flight
N11LR took to the sky today for it's maiden voyage. One hour flight went without incident. Seemed to have a bit of left wing heavy, but later realized that I had burned off way more fuel in the right tank with all of the ground run in, and by the end of the flight was levelling off a bit, so too early to tell. Barely a 1/3 of a ball off, so not much rudder trim will be required. Thanks to the 40* air temps, highest CHT didn't go north of 380. I was expecting an initial CHT drop in that first hour, but never got it. Oil temps climbed to and remained steady at 193 for the whole flight.
All in all, a good flight and an exciting culmination of 1.5 years of full time building. looking forward to further exploring it's envelope after a couple more breakin flghts at high power.
I ended up with an empty weight of 1630. No interior yet.
[IMG][/IMG]
Larry
Old 12-27-2019, 10:26 PM
dreed dreed is offline
Congratulations!!!! Looks like a beautiful 10!
Dan Reed
Camas, WA
RV-7A - N167DR
First flight 5/25/2021
Phase 1
2018/19/20 VAF dues paid
Old 12-28-2019, 12:29 AM
N941WR's Avatar
N941WR N941WR is offline
Great news Larry!
May you have many trouble free hours!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-28-2019, 01:19 AM
AlpineYoda AlpineYoda is offline
Congratulations! Good luck with the rest of the flight testing.
I put in 4.5 hours today - hoping to be up with you soon!
RV-10 build blog -- https://eaabuilderslog.org/?blproject&proj=7ZSwfzr2g
Started 12/19/2019
Engine hung 1/9/2021
Panel hopefully coming fall 2021
N1814T reserved with FAA
Donated Jan 11 for 2021, EAA and AOPA member
Old 12-28-2019, 06:04 AM
cderk's Avatar
cderk cderk is offline
Congrats Larry - hope to be in your shoes early this spring. I?m sure its a wonderful feeling to get the thing in the air and not have any major squawks!
Old 12-28-2019, 08:29 AM
Nukeflyboy Nukeflyboy is offline
Congratulations!!! Hope the weather cooperates so you can finish the test period soon. Then the real fun starts!
Dave Moore
Granbury, TX
RV-10 and Breezy
Old 12-28-2019, 06:41 PM
AviatorJ AviatorJ is offline
Congrats on the first flight!
Justin
RV-10, N10JW
Flying since 2/14/2019
http://operationrv10.blogspot.com/
Old 12-28-2019, 06:47 PM
Toobuilder's Avatar
Good stuff Larry!
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 12-30-2019, 10:55 AM
1001001's Avatar
1001001 1001001 is offline
Congratulations! Hope the Phase 1 goes smoothly!
Old 12-30-2019, 11:42 AM
MK77 MK77 is offline
Congrats Larry! Swing by UGN sometime, or I can head down to 06C in the -7.
Matt
Matt K.
RV-7 Tip-up - Flying!
XP Superior IO-360 w/cold air sump, Catto 3 blade prop
Garmin G3X
CFI, CFII, MEI
