Go Back   VAF Forums > Model Specific > RV-9/9A
Old 12-26-2019, 01:17 PM
Surfdoc Surfdoc is offline
Default Dynon Pitot Heater Module
Just wondering for all those that installed the heated pitot from Dynon in their -9. Where did you mount the heater module? Any photos or advice is greatly appreciated.
Old 12-26-2019, 02:39 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default On a rib accessible through the access panel
-7, not a -9, but the same idea... On a rib accessible through the access panel near the pitot.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,535 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 12-26-2019, 03:55 PM
airguy's Avatar
airguy airguy is online now
Just like this, with the screw heads facing the inspection panel so you can remove it if needed.
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 12-26-2019, 04:40 PM
Finley Atherton Finley Atherton is online now
On the outboard side of the end rib so it is easily accessible when the wing tip is removed.
Fin
9A
Old 12-26-2019, 06:37 PM
JRichichi JRichichi is offline
Default nutplates
And add some nutplates to the back side while you still can do it easily. They are lighter than a nut and washer and they won't fall off and roll to the most inaccessible place in the wing like a nut and washer will...
Old 12-26-2019, 09:55 PM
airguy's Avatar
And you can remove a screw from a nutplate with a long screwdriver and three fingers, while inventing new vocabulary, in a position where it would be absolutely hopeless to try to get to the backside with a wrench on the nut.
Save yourself maintenance effort during the build process, every chance you get.
Old 12-26-2019, 10:06 PM
griffg griffg is offline
Default Dynon pitot heater module
On my 7A I have installed it the same as Airguy except I have run all my earth wires back to the firewall earth block.
Gordon Griffin
RV-7A under construction
VH-NAK
IO-360-M1B
Catto 3 blade prop
Old 12-26-2019, 10:22 PM
jcarne's Avatar
jcarne jcarne is offline
I put mine on the access panel itself that is right under the aileron bellcrank. Maintenance doesn't get any easier than that!
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 12-27-2019, 06:00 PM
Maxrate Maxrate is offline
Just like Airguy recommended for easy removal should it need repairs. I also added a service loop for the dynamic/AOA feed should the pitot need to be sent in for repairs also. I would share pics but the Expercraft website has been down.
Mark Malone, RV7
Wings complete, SB 14 complied with, canopy and cowling in progress, Up on the gear.
N442MM reserved
http://www.mykitlog.com/MikeMike
2021 Donation gladly paid..
Old 12-27-2019, 06:03 PM
GeoffP's Avatar
GeoffP GeoffP is offline
Default Any Photos?
Jereme,
Have you got a photo you could share of what you did? I'm about to close up my left wing so timing of this thread is gold for me, and I was favouring putting the controller onto the access plate for maintenance reasons also. I could still modify the ribs easily enough (with nutplates etc as per others) as the skins aren't yet on my wings.
RV-9, Empennage and Wings about done, Fuselage taking shape.
