Old 05-16-2007, 03:02 PM
uk_figs's Avatar
uk_figs uk_figs is offline
Default Engine mount bolt holes
Getting ready to work on the firewall forward section and in checking the engine mount I received with the finish kit it appears to have holes for 6 bolts, one in each corner and two equidistant on the lower horizontal member. The fuselage only has 4 holes at the corners and a quick check of the drawings does not appear to show the other 2 holes.
Are these extra holes to allow for multiple installations and can be ignored on my RV-7 or have I missed something on the drawings? Mount is for 0-360.
Dave
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
Old 05-16-2007, 03:27 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Dave,
You need to drill all six holes. The lower two in the middle drill through an angle bracket that joins a pair of vertial angles on the fire wall and mating floor longerons. I'll post a picture later if it'll help.
Jim Sharkey
Old 05-16-2007, 04:19 PM
uk_figs's Avatar
Default Engine mount holes
Thanks, I will check the drawings again tonight as I did not see them on the firewall layout. I have a QB fuselage and the four corner holes were predrilled.
Dave's RV-7 Blog
Email me
Old 05-16-2007, 04:47 PM
jsharkey's Avatar
Dave,
The lower mid bolt heads are shown towards the botom of the above photo. Hope it helps.
Jim Sharkey
