Old 05-16-2007, 02:15 PM
kentb's Avatar
kentb kentb is offline
Smile where do I get spring loaded hole?
I have seen these used on wheel pants, so that you can put air in your tires without taking the wheel pants off.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 05-16-2007, 02:31 PM
rvpilot's Avatar
rvpilot rvpilot is offline
Default Here!
Here's the link-
http://aircraftspruce.com/pdf/2007In...l/Cat07107.pdf
But, I'd just drill an access hole if I had it to do over again!
Bill Waters
Based KCVC (Covington, GA)
RV6A - Gone, but not forgotten!
RV8 - Gone too, now winning races in the RV Gold Class!
RV4 - Flying!!!
Old 05-16-2007, 05:42 PM
f1rocket's Avatar
f1rocket f1rocket is offline
I used them on my RV-6. Expensive and mine didn't work that great. This time around, I bought some chrome hole plugs and just drilled a 1" hole in the wheel pant. Snapped in the chrome plug and away you go. Neat, simple, and cheaper.
But I understand the desire to use them.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 05-16-2007, 11:53 PM
osxuser's Avatar
osxuser osxuser is offline
They look nice in cessnas. I don't really like the single hole myself.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 05-17-2007, 10:03 AM
kentb's Avatar
Default Thanks for the link Bill.
After reading what you and Randy said, I think that I will go the cheap route and use the chrome plugs instead.
Kent
Kent Byerley
Canby, Or
Old 05-17-2007, 02:43 PM
pierre smith's Avatar
Default Extensions
Hi Kent,
After you drill the 1" holes, buy a pair of valve stem extensions and screw them together to make them long enough. A 3/8" nut driver is the size of the valve cap to remove it with, screw the valve stem extension in place and air up-simple. Once I located the valve stem behind the hole, I painted a white stripe on the sidewall of the tire straight down so when I see it, I know the valve stem's lined up.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 05-17-2007, 02:51 PM
kentb's Avatar
Thumbs up Thanks Pierre...
More good ideas. I love this site and the people on it.
Kent
Kent Byerley
Canby, Or
Old 05-17-2007, 05:40 PM
mtclay mtclay is offline
Default Check this out
This is what I use for adding air through the 1" hole -- neat and easy.
Check this link: http://www.cleavelandtoolstore.com/p...sp?number=VSE5
Cleaveland tools part number VSE5.
Mike Clay
Orlando, FL
RV-8A N81PD
