Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
  #21
Old 12-26-2019, 04:32 PM
RVDan RVDan is offline
Originally Posted by rv6ejguy View Post
I made up an array of seven 20 watt Halogen bulbs, which gave a measured current draw of around 11 amps which is close to what a 4 cylinder SDS EFI system draws with one pump running, the ECU, coils and injectors at 2500 rpm.
_.
When using light bulbs as a load, the load is essentially a pure resistive load. Applying Ohms law, the load will drop linearly as voltage drops. An 11 A load at 14 V will be 9.4A at 12V, and 7.85 A at 10V. There is a variable as the bulb filament resistance changes with temperature, but that is minor in this example. On the other hand, most modern micro based circuits, have a high inductive and capacitive factor, and tend to draw the same power (Watts) as voltage changes, meaning Amps actually increases as voltage drops. Therefore I believe that your duration tests are yielding erroneous results, in the bad direction.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 12-26-2019, 08:58 PM
airguy's Avatar
airguy airguy is offline
Valid point. You would need something like a constant-current driver on an LED array to accurately portray the usage.
Old 12-27-2019, 03:34 AM
emsvitil's Avatar
emsvitil emsvitil is offline
If you want a more constant Watts load, use a DC to AC inverter and put the light bulbs on the AC side.
As the DC voltage drops, the inverter will draw more amps to compensate for the voltage drop.
Ed
Old 12-27-2019, 04:26 AM
rmartingt's Avatar
Seems like one would want to size a LiFePo battery not by a single lead-acid-equivalent AH rating, but by using data from the manufacturer (or your own testing) of voltage vs. time based on discharge rate. I know EarthX provides this for their batteries, though I have not conducted my own tests to verify that performance.
I think Syvolo?s post might explain the results?for equivalent cranking performance (very high current, very short duration), the lead-acid battery will have more usable capacity at low (backup use level) discharge rates. For equivalent backup performance, the LiFePo will have more cranking performance. And I think this is because he lithium batteries have less of an efficiency penalty at high discharge rates.
RV-7ER - finishing kit and systems installation
Old 12-27-2019, 04:46 AM
svyolo svyolo is offline
Shorai's explanation was a bit wordy, but they did say they used 6 Ah cells in a battery they rate at 18 Ah. For their purposes of a start battery, that has validity. Had it not been for Ross's capacity test, I would have never read the fine print.
EarthX rates their capacity at a 1C discharge rate. So their 12 Ah rated battery is rated for 12 Ah capacity, based on a discharge rate of 12 amps. Their 12 Ah battery is about twice as heavy as Shorai's 6 Ah "18 AH" battery.
That adds up for me.
Old 12-27-2019, 06:04 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Valid point so you can do your own test on whatever gear you will be running on your backup battery- lighting, glass panel, coils and injectors, fuel pumps etc.
I just opened the door on the matter and have learned some additional information from the other posters here. This is an important topic for many people.
Bottom line, I learned that my total advertised AH capacity with 2 Shorai "18AH" batteries is closer to 12 AH in reality. I have maybe 40 minutes of flight time to zero if I lose the alternator. I'm glad I know that now as before I thought I'd safely have double that time. At the time I bought the Shorais, I found it hard to believe these small 2.2 pound batteries could do the same job as the 12 pound AGMs they replaced. For starting the engine, they actually do better, for extended running at moderate current draws, they clearly won't.
On batteries with a BMS, you won't get the full AH rating either as they will shut off before you can tap the full cell capacity- so the lesson is to do your own tests.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 12-27-2019, 08:19 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
SNIP...
Bottom line, I learned that my total advertised AH capacity with 2 Shorai "18AH" batteries is closer to 12 AH in reality. I have maybe 40 minutes of flight time to zero if I lose the alternator. ...SNIP
I caution against the myopic approach that the only failure to mitigate is loss of the alternator. While this is perhaps the most likely causality, it does not result in the most severe outcome. Many RVs I?ve seen have multiple single point failure risks (beyond the alternator) that will leave them with a dark panel.
If flying IFR I recommend a careful analysis of your power distribution and avionics, then test your analysis to see if it achieves your design requirements. For example run all the loads you will have for IFR flight in the hangar and see how long you can go. Now add a loss of a master relay, avionics master, common buss bar, etc. and see what you have left. For me my most limiting single causality leaves me with just one of two batteries that will yield 70+ minutes of fully supported IFR flight. The simplistic loss of the alternator yields 3+ hours of IFR flight.
My point - what batteries you use is important, how you build and test your system is more important.
Carl
Old 12-27-2019, 08:39 AM
rv6ejguy's Avatar
Carl
Both components are important but this thread just deals with with the battery discussion. For clarity, let's keep it confined to that topic please.
There have been plenty of other threads already on electrical system design/ layout and evaluation.
Old 12-27-2019, 08:43 AM
rocketman1988 rocketman1988 is offline
Default Oh, yeah....
"...There have been plenty of other threads already on electrical system design/ layout and evaluation..."
That's a fact...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 12-27-2019, 10:13 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I wonder if the fact the testing procedure being flawed is relevant or not.
As long as both batteries were tested with the same setup, they were both subject to the same testing error.
If the test was repeated with a correct setup, would it make a difference in the performance delta between the two batteries???
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
