05-16-2007, 11:57 AM
Proper Coax for Nav/comm
I am planning to install the Archer VOR and Com antennas in my wing tips. Not having the radios, I do not know the proper coax cable to run in the wings.
Can anyone suggest the proper coax or the impedence? Also any comments on how well these antennas work in the RV7 wingtips?
So far I have been given RG-58U and RG-174 as options.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
05-16-2007, 01:08 PM
If you want the very best, get Andrew FSJ1-50 50 Ohm cable. You can get it from Talley, who is a distributor for Andrew, at $1.49 / ft. They also have the $10 BNC connectors. LA - 1 800 949 7099; SF - 1 800 2323 4949
05-16-2007, 02:08 PM
I have them in my RV9A
Nav on the left along with 40" of unshielded coax for the marker beacon. Com on the right. One bent whip belly for my second com radio.
I am happy with the nav to both radios (SL30 and GNS430), but the com side the belly antenna can pickup almost twice as far away. I have not found this to be a problem, if I am a ways off I will just use the better antenna and when I get closer and want to pickup awos or the field freq. I just switch over to the wing tip antenna.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
05-16-2007, 02:49 PM
rg-142
I wouldn't use RG-58, It has too much attenuation. For COMS and Navs RG-142 works really well. (That's what we use here at a major helicopter completion center) If you need something a little more flexible you could use RG-400 that is about the same as 142 but the center conductor is stranded instead of a solid conductor. In my opinion the FSJ1-50 cable is really good but way overkill.
The most important thing on antenna installations is the bonding to the airframe.
My 2 cents.
A&P, IA, Avionics Tech, and finally: Pilot! (12/28/06)
Dying to build an RV10. Not quite ready yet
05-16-2007, 02:50 PM
Kent,
Thanks for the feedback on the range. Has anyone else had this problem? I'm not married to internal antennas if this is the expected loss over a belly mounted unit.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
05-16-2007, 03:22 PM
The problem with wingtip comm antennas is that the comm requires a vertically polarized antenna and wingtip is not thick enough to do it properly, so a vertically polarized antenna in the wingtip is a compromise at best. The nav antenna works well because it is a horizontally polarized antenna. Also, if the station you are trying to reach is on the side away from the antenna, the metal of the plane can block some of the signal. I am putting in a nav antenna in the wingtip and my comm antennas on the belly.
Paul Trotter
Sussex, NJ
RV-8 82080 Finish/FWF Kit
N801PT
05-16-2007, 04:02 PM
Limited com range in wingtip
I noticed that Archer also has an internal com for the tail. That would take care of the H/V thing but it appears to be too large for the RV7 tail fiberglass. Guess I'm going with the belly for com and wingtip for nav.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
05-16-2007, 04:36 PM
Belly Com
I fought this battle and lost. You will be happy with the belly bent antenna for the com. The Archer works great for Nav. My radio is an SL-30.
H. Evan's RV-7A N17HH 240+ hours
"We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
05-16-2007, 05:16 PM
For the runs used in the RV, good quality RG-58 works just fine. I've used it in many RVs and mine has been flying for 14 years with no problems at all.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
05-16-2007, 05:26 PM
fugio ergo sum
That is the key. Attenuation specs are normally given for a 100 feet. 10 feet of just about any coax at VHF isn't going to have much loss.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
