Old 12-21-2019, 04:01 PM
jim skala jim skala is offline
Default Crack in oil cooler mount
RV9 with just over 1000 hours.
The aluminum piece that the oil cooler is mounted to was found to have developed a long vertical crack in the bend area, running the length of the oil cooler, and the oil cooler then had play where it could move a bit (maybe 1/16") where the crack could open. At the top end, the crack had not yet completed its run, and it was the only thing left holding the oil cooler. This crack is in the aluminum sheet angle that the oil cooler is mounted to.
Observing the crack: Push the oil cooler aft with a little pressure. If there is a crack in the mount, it will open the crack a bit and the oil cooler will move a bit.
Repair: First I stop drilled the crack at the top end. Then I riveted on two doublers across the crack, one at the center (0.40 aluminum, a couple inches from the top), and a heavy one at the lower end, where the crack probably started. The doubler at the lower end is 1/16" angle. This repair made the oil cooler mounting completely solid, very strong.
It might be good to install the lower doubler before the crack can start to form.
Old 12-21-2019, 04:49 PM
vic syracuse vic syracuse is offline
Super Moderator
This is a very common problem on RV's that have the cooler mounted to the aft cylinder. We probably see 75% of them cracked and needing a fix.
Check out my webinar for some pistures.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 12-21-2019, 04:58 PM
RV8JD's Avatar
RV8JD RV8JD is offline
As others have pointed out, cracking of the baffle behind #4 cylinder with the oil cooler mounted there is pretty common. I purchased my first RV-8 with about 122 hours on it. The baffle cracked around 400 hours or so, IIRC. When we replaced the cracked sheet AL parts we also put in an extruded AL angle. The baffle has not cracked since, and that RV-8 now has 2,200+ hours on it.
I bought my current RV-8 with about 208 hours on it, and shortly after I bought it the baffle cracked on that one too. It has a brace between the engine case the baffle behind cylinder #4, but that didn't prevent the baffle from cracking. So we repaired it with the same AL angle fix, just as we did with my previous RV-8. So far so good, and I expect no cracking going forward.
Below are some pics from current RV-8.
Cracked:
Fixed:
Both RV-8s have parallel valve IO-360s, but my previous RV-8 has 10:1 high compression pistons. Both have Hartzell CS props.
I'm surprised Van's hasn't fixed that detail in the design yet (well, maybe not surprised since the RV-8s, 7s, 6s, 4s, and 9s are older models)!
(Oh, and "Skookum" is a technical term! )
Carl N.
Arlington, WA (KAWO)
RV-8, 790 Tach Hours
(Pic 1),(Pic 2)
- Out with the Old, In with the New
(Pic)
RV-8, 1938 Tach Hours (Pic 1),(Pic 2) - Sold
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 12-22-2019, 06:35 AM
bjdecker's Avatar
bjdecker bjdecker is offline
Default Different Material
In the for what it's worth department, at some point along the way - Van's changed the baffle material for Parts 4 & 5 in the IO-360 BAF kit from 2024-T3 to either 5052 or 6061 bare aluminium (unclad).
It's not reflected in the OP-04 drawing, but it's very apparent that it is now different material from the other pieces.
I don't know if they've changed this for the O-320, O-360, etc. baffles.
Cheers
B
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 12-22-2019, 06:50 AM
Scott Hersha Scott Hersha is offline
On my latest RV8, I made a doubler angle at that corner that also went under the side baffle angle to tie them together. I made this angle piece out of steel, probably about .030-.040 thickness. Primed, painted, it looks like aluminum, but much stronger. No cracks.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 12-22-2019, 11:54 AM
Ralph Inkster Ralph Inkster is offline
Also check for baffle cracking near the bottom inboard corner of the oil cooler. Pretty common to find cracks where the baffle starts curving under the lower half of #4 cylinder.
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
