Old 05-16-2007, 08:37 AM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
Default Baffle- Paint- Yes or No
Trying to figure out if painting the baffles is worth the time and effort.
What are the pros of painting. I know the cons: added weight, time to do etc.
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2020 donation current
Old 05-16-2007, 09:04 AM
f1rocket's Avatar
f1rocket f1rocket is offline
I think the biggest con is that they just don't look that good for very long. I painted mine, but they look a little beat up now.
If I were to do it again, I would go for polishing the aluminum and then just let them reach a natural patina. I think it's a cleaner look and will last longer.
If you do paint, you might consider having them powdercoated instead. That might be a little more durable.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 05-16-2007, 09:12 AM
gasman gasman is offline
Try a can of X-I-M 900 clear coat 800-262-8469 This stuff goes on easy, your parts look great and it is easy. Will dry fast and the finish is tuff.
Wash your part with Dawn dish soap and scuff with red scotch brite.............
Old 05-16-2007, 09:37 AM
az_gila's Avatar
az_gila az_gila is offline
Question Anodize
Anodizing might be an option that might look better (more metallic looking... ...) than powder coat.
It's an option on some aftermarket certified aircraft baffles.
Pricing might be not much more than powder coating if done in a single batch...
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-16-2007, 09:52 AM
Default I can't believe anyone would even consider it.
Bob Axsom
Old 05-16-2007, 10:24 AM
bsacks05's Avatar
bsacks05 bsacks05 is offline
Painted mine with flat black engine paint from an auto parts store. They look great after 95 hrs.
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 05-16-2007, 11:04 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I left mine bare - my experience with baffles on my old Grumman was that with all the vibration and wear, they'd be looking patched and ratty eventually anyway. With more than 450 hours on the Val's baffles now, they do look remarkably good - no wear or cracks - but I'm still satisfied that I didn't take the time to paint them. If I had, and they needed patching, the disassembly to repaint to make them pretty again would be a lot of work - I don't want to have to take them apart until it's time for engine overhaul!
Paint them, powdercoat them, or anodize them if it makes you feel better, but leaving them bare worked just fine for me.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-16-2007, 11:40 AM
JonJay's Avatar
JonJay JonJay is offline
I am always impressed with the guy at the fly in that takes his cowling off to show his beautiful engine compartment. There are some spectacular installs and I like looking at them, seriously. However, I did not paint anything that I did not have too, and in my opinion, baffling is one of those things. Decided flying sooner, even a few hours, was more important to me.
I do think that cracks are easier to see on naked aluminum, hence, I did not paint my airbox parts either.
I think there is no right or wrong answer here, just your personal preference.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-16-2007, 01:08 PM
N62XS N62XS is offline
Default Next time bare!
Paul
I'm in Paul's camp. I powder coated mine with a high heat silver finish. Came out OK, but not great. My 1963 Mooney had bare baffling. I took a rag and some Dawn to it and it cleaned up great. If I were to do it over, and I will at least three or four times, bare. Less time, little if any benefit and releatively easy to replace if it starts to look ratty.
IHN,
2020 Dues Paid
Robby Knox
THEM: Why do you always carry a knife?
ME: I can't open a bag of chips with my Glock!
Old 05-16-2007, 03:21 PM
ao.frog ao.frog is offline
Default Doesn't paint isolate?
Hi.
I'm working on the baffles right now and I'm planning to leave them unpainted.
The reason is that I'm thinking they'll be able to transfer heat more easily from inside of the plenum to the outside, thus making the cooling more effective?
I was thinking that paint will act as isolation?
Or am I wrong here maybe?
Regards Alf Olav Frog / Norway
Finishing
