12-23-2019, 09:11 AM
Originally Posted by RV74ME
I confirmed that the wires were reversed at dsub (lo was hi, hi was lo)
Well, good you got to the solution.
Bill
RV-7
Lord Kelvin:
12-23-2019, 10:19 AM
Originally Posted by snopercod
Water boils at 210.5 F at that altitude, so no big deal. I'm not convinced that you found the problem, though. If the wires were reversed, you would be sending negative voltage to the box and get the big red X again. Maybe they're reversed at the box and somewhere else, too?
Guess i should clarify. I knew back when i did first engine run that the dsub was wired backwards. I got the big red X?s. so instead of pulling all that apart, i took (what i thought) would be path of least resistance. So i hooked up red to yellow, yellow to red to the leads of the probe. This gave me temperature indications, but just not accurate. Didnt know how inaccurate it was until first flight
Steve T.
CFII/MEI/ATP 737,DC-10
RV-7 slow build
AUO
12-23-2019, 11:00 AM
Guess i should clarify. I knew back when i did first engine run that the dsub was wired backwards. I got the big red X’s. so instead of pulling all that apart, i took (what i thought) would be path of least resistance. So i hooked up red to yellow, yellow to red to the leads of the probe. This gave me temperature indications, but just not accurate. Didnt know how inaccurate it was until first flight
"Least resistance"
Given the wire type differences and resistance down the length, probably gave you the most resistance
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
12-23-2019, 04:03 PM
So what you had there was three thermocouples in series. One at the probe in cylinder head, another at the junction between the probe and lead wire, and a third at the D-sub connector. You do the math...
(2020 dues paid)
