Old 12-17-2019, 12:52 AM
Draker's Avatar
Draker Draker is offline
Default Waiting for the warm weather
Bad timing: I'm ready to start working with canopy plexiglass but it's in the freezing middle of winter. Nope! Gotta look for some other stuff to do in the mean time. Looks like there is plenty of canopy related work, but the plans have you doing them after the plexiglass is in place. Any reason that some or all of these can't be done before the plexiglass work? Canopy reinforcement brace kit, side skirts, canopy lift struts, aft canopy latch lugs (the parts that engage with the latch "fingers"), interior canopy handle. Do I really need the plexi fit to do these?
If I really have to wait, I guess I can set the canopy frame aside and work on the engine mount or something. Or start fiberglassing the empennage. Or start installing avionics. Or the wiring harnesses. Or the stick grips. Or pull the trigger on a panel. Come to think of it there's plenty of stuff to do at this stage!
Ryan Drake
Livermore, CA
https://stiletto.smugmug.com/RV7
Donated 12/31/2021
RV-7A (N12VD): Finishing final tasks for engine-start and airworthiness!
Old 12-17-2019, 06:15 AM
snopercod's Avatar
We don't usually see Livermore, CA and "cold weather" in the same post. Why not knock together a small workroom out of 2x4s and Visqueen and put a small heater in it?
(2020 dues paid)
Old 12-17-2019, 07:20 AM
I put an electric space heater inside the cockpit of the airplane for part of my canopy work...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 12-17-2019, 09:54 AM
rapid_ascent rapid_ascent is offline
Ryan,
I moved on to working on some engine mount / firewall stuff. There is also the brake assemblies. Well there is always plenty to do it seems...
Ray Tonks
2022 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 12-17-2019, 10:34 AM
PilotjohnS PilotjohnS is offline
Default Same Boat
I am in the same boat. Ready to start canopy. But I think I will wire up tail cone and work my way forward. I am not sure if I can do firewall forward without gear on. Plane is too tall for garage with gear and I am height challenged.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2022, worth every penny
RV9A- Status:
95% done, 5% left to go
Structure 98% done (less gear and windscreen)
Electrical/Panel done
Firewall Forward 95% done (waiting on stuff to be done)
Fiberglass 15%
www.pilotjohnsrv9.blogspot.com
Old 12-17-2019, 06:57 PM
RV7 To Go's Avatar
RV7 To Go RV7 To Go is online now
I did my 7 tipper with the fuse sitting on short supports while doing the canopy, FWF stuff as well as the panel and most wiring etc. (Same issue with the low garage height). I then had to remove the canopy to install the gear while doing the brakes, fairings, cowl, wheel pants etc. I found most tasks were a lot easier with the fuse at a lower height off the gear. Still remember being at the 90 percent done and 90 percent left to go stage!
Al
___________
RV4 - Bought 2013 Sold 2017 after 450 hrs
RV7 - Built in 6.5 yrs & Flying 2017
RV4 - Built 2021 Time flown and Sold
Old 12-17-2019, 07:03 PM
jcarne's Avatar
jcarne jcarne is offline
Yep, after this you will have to stand on a 5 gallon bucket or ladder to do just about anything. Luckily I was almost done with my wiring before I put her on gear.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Old 12-17-2019, 07:26 PM
wirejock's Avatar
wirejock wirejock is offline
Default Canopy
I did mine in chilly temps in May. Just heat the area before cutting. Actually, I never got above 70. Pretty cold at 7,500'. It can be done. Now I'm working a one piece fiberglass skirt. I would recommend getting the frame as close as possible plus 1/2-3/4" before touching the canopy.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
