Originally Posted by SegevFly
Hi All,
Firstly - thank you for your time looking into my engine issues.
The engine is installed in a Pitts S1S and is a vertical intake. Therefore no sniffer valve, nevertheless, the oil just simply run out of the throttle body, then into the floor via a small drain hole which is located in our air intake.
Based on the comments and suggestions provided, I am going to try and locate another sump, install it on our aircraft and fly to identify if it is the issue, if it does, I will get a new one from Superior or Lycoming
While perhaps costly, I am unable to determine what the oil is coming from otherwise..
I attached some additional pictures for your information, and I promise to let you know how I go!
https://ibb.co/syt2KgJ
https://ibb.co/mHH9Vkz
https://ibb.co/CQ8JjHs
https://ibb.co/nwQ9Xqy
https://ibb.co/hBvxC0c
https://ibb.co/jwgmRH1
Thank you again,
I would check each drain back line from the rocker boxes. A plugged line will allow excess oil to accumulate in the rocker box and if / when the level gets up to the intake valve guide, will leak into the intake runners. Pull them quickly after a long engine run and it will be obvious if you have a plugged line. This type of problem would only creating dripping on the floor after long runs and not after short runs. You also want to pull each intake tube and check for wet oil. You want to know which cylinder (possibly multiple) is the source.
Clearly a casting crack could cause this. However, it is a tough diagnostic exercise to start with and seems less likely with a sump that has not leaked for many years. If you find a wet intake tube, you can eliminate the sump as the culprit, so would start there.
Larry
