12-15-2019, 10:03 AM
If even remotely thinking about formation flying; CS.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
12-15-2019, 11:28 AM
Welcome to one of the never-ending debates!
As others have said...it is critical to define your mission first. The decision may be simpler after that.
CS is typically heavier. CS has better TO performance. Both have almost the same performance in cruise, as has been documented on the forum in the past. I fly a FP 7 and have confirmed this with other CS RVs on our field. One other benefit to the CS is in slowing the plane down. The CS is like having air brakes. With the FP you have to be more aware of your energy management. There is more complexity and maintenance with CS.
One thing not really discussed is the maintenance. There is more to inspect with the CS prop and controls. CS according to the manufacturer requires an overhaul at specified time or hourly intervals. Can be expensive. In Canada FP metal for Certified requires 5 yr corrosion inspections (not sure what the US requires). Costs much less in time and money. You can debate whether or not to do it on a homebuilt.
Al
___________
RV4 - Bought 2013 Sold 2017 after 450 hrs
RV7 - Built in 6.5 yrs & Flying 2017
12-15-2019, 11:30 AM
Really? Why? I thought the idea was to use the throttle the most, but I'm not a formation flyer.
-Marc
RV-10
N814RV
2020 Donation Made
12-15-2019, 11:43 AM
-Marc
You still use the throttle but the speed of the airframe reacts quicker due to the governor adjusting blade pitch. This is generally a good thing but one should be aware of the limitations on counterweighted engines concerning the prop "driving" the engine. Using the prop as an "airbrake" is a bad thing on some engines.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
12-16-2019, 07:28 AM
Formation with a fixed pitch prop works out fine. You just need a little more ?talent?/anticipation. Energy management takes on a new level of importance.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
12-16-2019, 07:55 AM
Don`t tell this to Luca and Franz from the Formation Aerobatic Team CrewRV8.. They both have a 3 bladed fixed pitch Catto Prop?
(and this was the reason why I chose one too. Its simpler, lighter, cheaper and if they can fly formation aerobatics it is good enough for me... )
Yves - Basel, Switzerland
RV-8 #83458 HB-YUA
Donation 2019 done
12-16-2019, 11:59 AM
A Corvette will start in 4th gear, and can attain nearly its maximum velocity on level ground in 4th gear. Would you buy a Corvette stuck in 4th gear?
Many of us do exactly that. You don't "wear the clutch out" because the clutch is air, but you do pay a climb penalty and don't have as many power / rpm choices (your power gives you whatever rpm it gives you, you can't run full power / lower rpm).
Like any nice feature, the trade offs are complexity and cost. If money is no obstacle, a Cessna Caravan will do just about anything any RV will do and carry passengers too...
12-16-2019, 12:09 PM
Only as far as the prop driving the engine, but that is true. Pulling the power back far enough to put the pitch on the fine stops but not yet driving the engine (9 or 10 inches MAP) results in really good drag to slow the airplane.
12-16-2019, 12:52 PM
If only all pilots had that level of awareness and finesse. Based on what I hear in the pattern and from word of mouth, there are a lot of people chopping the power and "throwing out the boards".
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
12-16-2019, 01:56 PM
My method may be a little unorthodox, but I basically come in to the pattern the same whether I?m flying a F/P or a C/S.
I come screaming in to downwind at a fairly low altitude and fairly tight to the runway. When I?m abeam the numbers I pull power and pitch up. By the time I?ve climbed back up to a proper (normal) approach altitude I?ve bled off enough airspeed that I can then push the prop full forward without ever increasing the RPM?s. Then basically, all in one motion, I?ll kick her around and turn from downwind to base to final. The C/S will then act as my air break and I can almost point the nose straight down and still be going slow enough to deploy two notches of flaps all while keeping the RPM?s in a normal range.
If I?m flying a F.P. my procedure is exactly the same, other than not being able to point the nose straight dawn on final..... my final approach has to be a little bit flatter to keep the speeds where I want them.
Mark H.
RV-7- IO-360, EFII, Whirl Wind C/S, (Built and sold)
RV-4- O-320, Catto three blade, P-Mags (Sold)
RV-8- IO-360, Hartzell C/S (Flying)
RV-7- (Building)
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
