I think I must be mis-interpreting what the plans are showing for assembling the W-925 flap hinge brackets. I cut the corner off the W-925B-L (the 0.75x0.75x31/8 aluminum angles with the slight bend at one end) as shown on DWG 14. But when I hold this up to the W-925A as shown in the plans it doesn't look at all right. The photo linked below should explain what I mean... this isn't right is it?
***EDITED - when I put this on the wing and look at how it fits together with the rear spar, it actually looks like this is right (just looked odd by itself)... please correct me if I'm wrong!
Another question - all the holes for attaching the W-925A are pre-punched in the inboard rib, but only two of the holes are pre-punched in the other ribs... why is this??
