Originally Posted by no7rosman
I am going to do another scope and look at the scratches again, and will also do another compression test. If the compressions are good...Guess I'll just fly it.
Will also take a close look at the rest of the cylinders to see if they look any different.
I agree with your course of action.
I couldn't see a lot of your cylinder walls in the video, but what I did see looks good to me; you have good cross-hatching (which comes from the cylinder honing process) and some minor vertical lines (most likely oil streaking) - all very normal. Assuming compressions are good (and by that, I mean within about 10% of the other cylinders), I'd just fly it and consider what you have as normal.
But do check into fuel distribution, cylinder cooling and temperature bayonet distances. If you have an overly rich or lean supply to #3 compared to the other cylinders, that could cause it to run cooler - EGT's would be the primary indicator of this. If you have excess cooling to #3 compared to the others, CHT would run cooler. If your temp bayonet is farther down the exhaust pipe than the other cylinders, this would cause EGT temps to run cooler, but CHT's would not be affected - however you could pull the CHT bayonet, clean it and reinstall with a good nickel anti-seize to ensure good seating for more accurate temps.
