Old 12-03-2019, 02:41 PM
togaflyer togaflyer is offline
Carl, can two 625 be ran with a single buss one switch system. Would there be any benefit (if you can) over a 925. Thanks.
Old 12-03-2019, 05:29 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
The short answer is yes - the longer answer is don?t waste your time. This is not the reason for two PC-625s. The redundancy of a thoughtful, dual battery power distribution design should be your focus.
Carl
Old 12-05-2019, 07:19 AM
Carl, thanks.
So a battery question for all. I was at Costco and saw a group 51R AGM battery (you can also get this battery at Advance Auto, etc). 450 cca, 85 amp hours. Battery is 9.25 long and 5 inches wide, weighs 27 lbs. you can get post adaptors to match the wire terminal rings. I already have an Odyssey 925L arriving today (which is an AGM type battery), but made me think for next time. Width is good, expand the tray length 2 1/4 inches. You have over 100 cca over the Odassey. Are there any negatives anyone can think of?
Old 12-06-2019, 11:47 AM
lr172 lr172 is offline
Carl, thanks.
assuming the specs are not inflated, that is about double the amp hours at the same weight as the odyssey. Major red flag. low quality batteries skimp on the thickness of lead plates to save cost and this significantly reduces the amount of times they can be discharged below about 30% before the plate is gone (i.e. fail). If it spends it's life floating at 90%+ capacity this is not an issue.
Ever lift a marine or deep cycle battery? Weight is directly related to cycling longevity.
Larry
Old 12-06-2019, 12:09 PM
Ya and I looked and there is no way it would work anyway. Wishful thinking. Just discovered that UPS tossed my new Odyssey battery on the wrong truck and it went to New Jersey somewhere. Talk about a goat rope. Now I’ve resorted to overnight shipping from another company.
