Old 11-27-2019, 08:31 AM
bigginsking bigginsking is offline
Default Request: Stick Valve Engine monitor data
Hi,
Savvy Analysis is looking for data leading up to stuck valve events. They want to try to predict stuck valves or the risk of a stuck valves before the actual event.
If anyone had a stuck valve, particularly where the pushrod was damaged, and has engine monitor data leading up to that even please send me a private message and I'll put you in contact with the Savvy personnel doing the analysis.
Bill
N84WJ, RV-8, 1450 hrs. (no stuck valves)
rv-8.blogspot.com
