Old 11-27-2019, 07:23 AM
steve murray's Avatar
steve murray steve murray is offline
Default Why Castle Nut on Vert Stab & Rear Spar attach?
Why are Castle nuts used on Vert Stab and rear wing spar attach points?
I am following the plans but trying to understand why a standard Nylon lock nut is not used? Is there some type movement between these mating parts?
Steve
RV10 - Flying (Jan 2020)
RV8 - Built 2006- Flown 800 hours Sold 2021
RV4 Kit Purchased 2021
Old 11-27-2019, 08:20 AM
RV6_flyer's Avatar
Self Locking nuts are not used where rotation of the joint is possible. The wing can flex up and down in flight depending on weight of the aircraft and load on the wing. This can over time, loosen the rear spar nut.
Yes you have self locking nuts called out on some of the control bellcranks. The location of these self locking nuts are where bearings are used and the bearing take the rotation and not the bolt - nut.
Gary A. Sobek
NC25 RV-6
Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 11-27-2019, 09:26 AM
rvbuilder2002's Avatar
The fasteners you mentioned can be subject to rotation (as Gary already mentioned).
We often think of bolted assemblies on aircraft to be entirely static but they can move under certain load conditions.
For example - Under high G's, wing tips can deflect up to 1.5 inches or more depending on load and model. If the wing is deflecting, there would be a very slight movement at the rear spar clevis joint, so a castelated nut and cotter pin is used.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 11-27-2019, 02:00 PM
Snowflake's Avatar
Is that true for the Vertical Stab attach points as well? That was also part of the original question. Mine was assembled with Nylock nuts, I didn't even think to question it when I saw them...
Rob Prior
Old 11-27-2019, 03:00 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is online now
Vert. attached with AN365 lock nuts per DWG27A.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 11-27-2019, 03:58 PM
On the -10, it is a AN-310 castle nut
Steve
Old 01-02-2020, 02:47 AM
Tdeman's Avatar
Tdeman Tdeman is offline
That is because the front spar of the vert stab attaches with only a single bolt/nut on the 10, unlike the others which use a grid of 4 bolts. So the flexible structure (the entire vert stab) anchored at a single point needs to be thought of as pivoting minutely around that bolt.
The vertical stab of the 10 is similar in attach method to the main wing, with the difference being the front (instead of aft) spar being the single point used to set sweep/AOA.
This post brought to you in part by, pour-over coffee, sleep deprivation, and a need for speed.
Opinions expressed in this post do not necessarily represent those of my employer.
Old 01-03-2020, 04:50 PM
Steve Melton's Avatar
that single bolt may protect against structural bending interaction of the horizontal and vertical stab.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
