Old 05-13-2007, 02:37 PM
andyrv andyrv is offline
Default Superior XP prop governor line
I received my new XP-IO360 last week. It has a flexible line from the front right of the engine to the prop governor location instead of a stainless pre-bent line. Any thoughts/experience with this setup?
Andy
Old 05-13-2007, 07:15 PM
GAHco's Avatar
GAHco GAHco is offline
Default Well.....
That would depend on the Specs and quality of the line.
It also depends on if the fittings at both ends are steel or stainless steel.
There was an AD some while ago that had the aluminum fittings from the governor to the front of the engine required to be changed if they were aluminum, to steel.
Its an experimental engine and not even certified itself, but its pretty much cloned with some improvements, but it would be wise not to repeat the errors of other along with the good things.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 05-13-2007, 08:08 PM
GaryK's Avatar
GaryK GaryK is offline
Default Prop Governor line
Andy,
Aero Sport built my engine and also supplied a flexible hose instead of the traditional solid line. I ran it over the top of the cylinders, 320 hours and no problems.
Gary
N715AB
Old 05-13-2007, 10:50 PM
GAHco's Avatar
Originally Posted by GaryK
Andy,
Gary
N715AB
I could see that nice and beefy steel fitting too! Good Job guys!
Get em in the Sky!
Tom Brink Pres.
Old 05-14-2007, 12:31 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Lycoming says....
This hose is covered in Lycoming Service Instruction SI 1435.
It is the same SI that covers conversion from FP to CS operation. For an O-360, the SI calls for a 3/8 hose 36 inches long with straight ends.
It calls for a Teflon hose with firesleeving to TSO-C53A - Type D.
The SI has some specific mounting instructions... it might be good for you to get a copy.....
Added...
An AeroQuip data sheet is here for the correct hose with an integral firesleeve... hope the link works...
Aeroquip link
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-14-2007, 06:21 AM
Walt's Avatar
Walt Walt is offline
Default ECI provides the rigid line
with their kit, which to me is the more desirable solution. The rigid line is inherintly less prone to failure or aging issues than the flexible line. JMO.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-14-2007, 09:56 AM
az_gila's Avatar
Exclamation AD...
Providing the AD referred to above (post #2) has been complied with....
Steel nuts, not aluminum, on the rigid line.... something to look for if you are getting older parts....
AD 90-04-06
Of course, new ECI parts should be OK...
gil in Tucson
Gil Alexander
Old 05-14-2007, 12:30 PM
nucleus nucleus is offline
Default High Pressure Prop Oil Line
Superior has those lines made by Varga Enterprises (800-966-6936). Mine was so long that it was ugly, so I had Varga make me a shorter one. They are built to withstand much more than the 800 psi they should ever see. They have an integral firesleeve.
Hans
Old 05-15-2007, 12:33 AM
Rivethead Rivethead is offline
Here's another look at a flex line. I have a stainless steel line (unused) if ya'll want to buy it.
http://http://www.rvproject.com/20030720.html
Old 05-15-2007, 09:29 AM
osxuser's Avatar
osxuser osxuser is offline
It's ok by the AD, but I fail to see why anyone would want that over the stainless line. Replacement every 5 years vs. life the the engine and beyond.
RV4 wing in Jig @ KPOC
RV7 emp built
