Old 11-17-2019, 08:27 PM
Originally Posted by RFSchaller View Post
I used bathroom scales. I had three and took three readings rotating the scales so that I had one earring from each scale at each wheel. Then I averaged the three readings at each position for the aw&B calf. I reasoned that would average out scale errors.
Read my post. This is faulty reasoning. Random errors are reduced by averaging, but systematic ones are not.
Old 11-18-2019, 08:04 AM
bobg56 bobg56 is offline
Thanks guys for all your info!
Old 11-18-2019, 06:49 PM
RFSchaller RFSchaller is offline
Bob,
It?s easy to do a few known weight checks in the 150-300 lb range if you are that concerned.
Rich
Old 11-19-2019, 08:30 AM
Rrhsch Rrhsch is offline
I use 3 digital 440 lbs postal scales. Purchased them on amazon for about a $100. I use three 1/2 inch plywood ramps and leveling blocks to put the plane at the proper level for weighing. I zero out the scales with the ramps and leveling blocks on the scale. Simply move the ramps in position and pull the plane up on the scales. The time out timer starts once the weight has stabilized on the read out. I just push a little on the plane to keep the scale active until I am ready to read each scale. It?s cheep and works well. Scales are very accurate and can be checked against them self using any ?standard? weight you wish. I used bar bell weights.
I reweigh my plane with every mod I make. Here is the link.
http://www.amazon.com/Smart-Weigh-Sh...NsaWNrPXRydWU=
Old 11-23-2019, 09:22 PM
DaveWelch DaveWelch is offline
Thumbs up Scales
Wow! Awesome find!
A here I was sweating a re-weigh after a few mods.
See??? Next years "dues" have paid for themselves already.
Dave
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
Old 11-24-2019, 07:00 AM
Crafting N112DR's Avatar
Crafting N112DR Crafting N112DR is offline
Got 3 ($35) Amazon Stainless Steel Large Platform, 440 lbs Capacity Postal Scale. Seams to be very accurate. Only down side is that you have two minutes to weigh the aircraft because they will shut off after that. They are very accurate, I put a known weight of 300 lbs on them to see how accurate each one was and they where all right on.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
___________
David Rohrlick
PPSEL, A&P
RV-12iS Completed
Airworthiness signed off by the FAA 1/23/2020
First Flight on 3/14/2020
Phase I Finished on 5/7/2020
Need:
Paint?
Serial#12-0864
N112DR
https://youtube.com/c/CraftingN112DR
VAF donation made for 2020
