Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #11
Old 12-13-2019, 06:26 AM
PropMan PropMan is offline
Originally Posted by gmcjetpilot View Post
Remember to check and re-torque your prop often (as wood shrinks and expands with moisture. You have to have proper crush plate(s) I recall. Van's "RVator" articles decades ago had many articles about wood props; many more folks were flying with them. In rain slow way down RPM and AS.
Exactly right! But remember, not all wood props are created equally. Torque will vary with the density of the wood type and thickness. The multi-laminate can be torqued at a much higher value than a plank prop.
Crush plates should match the diameter of the crank flange, or in the case of RVs , the extension. 7" is preferred over 6". Especially for 150HP and up applications.
In rain, as long as you have good leading edge protection, normal cruise settings are acceptable.
Frank
RV6-N164FJ sold sadly
Legal Eagle w/Verner 3VW
Rans S7s
RV4- in progress
