Old 11-11-2019, 03:42 AM
Michael60614 Michael60614 is offline
Default New/Old O-320
Found a new plane with new low hour Lycoming O-320 (150hrs) but it has not run in 4 years and am considering on making an offer on the plane! Any advice?
mrellinger@rcn.com
Old 11-11-2019, 08:28 AM
SPX SPX is offline
mrellinger@rcn.com
Plan/budget on needing to do an engine overhaul or repair.. and be pleasantly surprised if you don?t have to.
RV-9A, Fallbrook Ca (L18)
Paid, Jan 2020
Old 11-11-2019, 09:17 AM
Robin8er Robin8er is offline
Depends how/where it was stored. If its in a low humidity environment then its plausible that its fine. The only way to really know is to pull a cylinder and look inside. The cam shaft is known to be the place that gets corrosion the easiest in a Lycoming.
I would factor possibly needing engine work into the cost of the airplane, buy it at a price that you aren't upset if you need to invest money in the engine.
My engine sat for 10 years, but was inspected prior to being installed. So far its a happy engine.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
