Go Back   VAF Forums > Main > Safety
Old 11-08-2019, 08:00 PM
mulde35d's Avatar
mulde35d mulde35d is offline
Default Pneumatic Squeezer Injury Lesson Learned
Lesson 1: Take your finger off the trigger of a pneumatic squeezer while adjusting the ram depth.
Lesson 2: If your going to accidentally squeeze your fingertip, try to have flat dies installed rather than dimple dies. Had this been dimple dies I likely would have lost the fingertip.
This is what a flat die squeeze looks like on the middle meaty part of the fingertip. Luckily it was set for AN426AD4-5 rivets and the dies had about 3mm space between them when fully pressed.
Hopefully nobody needs to repeat my error to learn this lesson.
Jon
http://www.mykitlog.com/mulde35d
RV-14A Sold
RV-10 Empennage - Searching
Wing - On Order
Old 11-08-2019, 08:08 PM
wirejock's Avatar
wirejock wirejock is offline
Default Welcome
Welcome to the club.
There's also the "Drilled a hole through the finger" club. Hope you don't join that one. Hurts!
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 11-08-2019, 08:15 PM
johnbright's Avatar
johnbright johnbright is offline
Default finger under trigger
On the CP 214 squeezer you can place a finger under the trigger so it won't move. Better of course to disconnect air.
John Bright, RV-6A, N1921R reserved, at FWF
O-360, 8.5:1, vert sump, dual SDS EFI EM-5-F
Z101 as a template, links
Old 11-08-2019, 08:29 PM
mulde35d's Avatar
Default Later
Two stitches, a bill for X rays, and quite a few swear words later and it?s all good.
Jon
RV-14A Sold
Wing - On Order
Old 11-08-2019, 08:37 PM
jcarne's Avatar
jcarne jcarne is offline
When I saw the title of your post I knew it was going to make me cringe. Confirmed. The thought of this happening has haunted my dreams before! Glad you didn't lose your finger.
Just out of curiosity, what yolk did you have on it?
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 11-08-2019, 10:32 PM
scsmith scsmith is offline
Ouch!
I treat a pneumatic squeezer the same way that I treat my framing nailer, which is also the way I treat my skeet gun. I treat the pneumatic tools like they are loaded guns unless the air hose is disconnected. I treat the gun like it is loaded, unless the action is broken open and I can see daylight at the ends looking in from the chambers.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2020
Old 11-09-2019, 05:48 AM
JDA_BTR JDA_BTR is offline
I bet you only do this once! Drills have had a way of finding my finger despite my attention to not repeating.....
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 11-09-2019, 05:57 AM
RV7ForMe RV7ForMe is offline
Default Blood sweat and tears...
I try to make a point of disconnecting the air before I adjust it but thanks for posting. I will think about that picture next time I am working with it.
Hope it doesn't hurt and heals quickly.
VAF dues paid for 2021
RV7-A (N137MX Reserved) - Wings Started...
RV7-A - Rebuild Done - Flying!
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
Old 11-09-2019, 06:06 AM
mulde35d's Avatar
Standard 3? yoke.
I had been pretty good about treating it with respect, but as with most things that we do a few thousand times over I ended up getting a little complacent.
Jon
RV-14A Sold
Wing - On Order
Old 11-09-2019, 09:12 AM
jcarne's Avatar
Originally Posted by mulde35d View Post
Standard 3? yoke.
I guess that is a tiny ray of sunshine here. A 1.5" likely would have been worse to due the lack of flex like the 3". Man...
Jereme Carne
PPL
