Go Back   VAF Forums > Education > Instrument Flight Rules
  #21
Old 11-08-2019, 05:34 AM
BillL BillL is offline
Default FWIW
Originally Posted by Tailwind/RVGuy View Post
+1 On a "hand off" that is exactly what I use: "Denver Center- N12345 - 8500 ft" Tells them exactly what they need. They were expecting you and they just need to know you are there and what altitude you show.
Lately, I had several issues when checking in (IFR flight plan). Three times on long cross countries, the controllers were working multiple frequencies and although I could not hear, they were busy. Very busy, so I have begun to just call out my tail # and wait. Then "RV226 whiskey lima level eight thousand"
I add the "level" because in a flight (two different flights) with 13 handoffs, ATC asked if I was level more than once. I don't know what they may be seeing as I was level on AP the whole time. Usually in smooth air.
Anyone know why they would ask, and should I continue with the "level" call out?
Bill
RV-7
Lord Kelvin:
Old 11-08-2019, 05:36 AM
don rv6 don rv6 is offline
there are no pronouns in air traffic. say,,call sign, altitude,anything important, then listen,,,,,,
Old 11-08-2019, 06:06 AM
RV6_flyer's Avatar
Originally Posted by RV8iator View Post
None is as bad as the dummy that says,
Wait....
Wait...
Any traffic in the pattern please advise.
Sounds like fingernails on a chalkboard.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 11-08-2019, 06:37 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default 122.8
Wait....
Wait...
Try that in Central Texas where most airports are on 122.8. The guys that say this usually forget to start with the airport name. Almost as bad as a meow-war on guard. Lots of fun!
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 11-08-2019, 06:56 AM
rocketman1988 rocketman1988 is offline
Default ...and
"...so I have begun to just call out my tail # and wait. Then "RV226 whiskey lima level eight thousand"..."
...and you contribute to the congestion on the frequency because now he has to ASK for the information that you should have provided on the initial call and you have to answer...again...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 11-08-2019, 07:40 AM
lr172 lr172 is offline
They likely haven't paid much attention to your blip on the radar until you checked in. The fact that your blip doesn't show a vertical velocity at the moment they look at it, doesn't necessarily mean that you won't be in another few seconds. ATC is always looking to confirm "your understanding" of your clearance and intentions when checking in, not just what the strip says. You should always include "level" or other mode when checking in, IMO. It is a redundancy designed for safety in the IFR environment.
Larry
Larry
Old 11-08-2019, 08:05 AM
jbDC9 jbDC9 is offline
Nope, read again what he wrote. He?s checking in (holy cr@p I said the bad words!) on a IFR flight plan, not calling to request flight following. No extra congestion caused here.
Originally Posted by KleensRV6 View Post
One of my personal upsets are pilots failure to listen on the new frequency before reporting in. If a controller is giving another aircraft control instructions they really don?t want to hear anyone?s else?s ums and awhs until they know United 680 has visual with the traffic they have pointed out to them. My rule of thumb is to give the frequency at least 5 seconds before making my initial call. YMMV
Exactly! A huge peeve of mine is just this; flipping to a new frequency, mash the PTT and start yakking. I hear it multiple times every day and it drives me nuts, it?s just freakin rude. The worst I?ve seen was one night at Denver; on a visual approach I switched to tower with the usual ?Good evening Tower, United XXX visual 17L?. One second after I released the PTT some idiot Southwest guy starts talking, also checking in with tower. I wanted to hug the tower guy as he ignored SWA and cleared us to land...
John Bixby
RV-8 QB sn 82030 - 1750 hrs
O-360-A1D/CS/Pmags
Houston, TX
Old 11-08-2019, 08:51 AM
crabandy crabandy is offline
Bill, just curious if it was a point to point normal XC or a multiple airport multiple approaches bouncing in and out of different facilities.
Flight plan info to/from centers, approach controls as towers doesn?t process the same. Some routes like IAF?s versus landing airports and temporary versus filed altitude can raise questions as to what the aircraft is or wants to do.
RV 7 400 hours and counting
19 donation done
Old 11-08-2019, 08:56 AM
Default Atc
?...Nope, read again what he wrote...?
I did... and I read it to mean he called atc with his call sign, waited (unkey the mic) and then made another call. If he actually kept the mic keyed, the result is the same; no one else can talk...leading to frequency congestion.
The guide on proper phraseology is pretty specific and can be found in a link posted in a previous reply.
Overall, I think the majority of folks using the system do a pretty good job, even if the phraseology isn?t quite standard...there will always be the couple percent that mess it up, though...
Bob
RV-10
297 HP Barrett Hung
Wiring...
Old 11-08-2019, 10:44 AM
Southern Pete Southern Pete is offline
Always extra points if the pilot has a proper British accent....
Perhaps that I always found controllers helpful when I lived in the US!!
