Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
Old 11-06-2019, 08:32 AM
bsmith51 bsmith51 is offline
Default Airflow Performance Setup - Help Needed
Looking for anyone knowledgeable of the AFP system who I could pay to help set up this new installation. It requires 2 people. Trouble is, the plane (a Long-EZ with O-320) is at The Dalles. I've tried the local mechanics w/o success. Thanks.
Bruce
Old 11-06-2019, 11:14 AM
RVDan RVDan is offline
I have an AFP FM150 and am curious what you mean by ?setup?. I did the installation and idle and mixture adjustment myself. Admittedly a little tedious to run, shutdown, adjust then repeat until right.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 11-13-2019, 11:25 AM
Default AFP System Adjustments
Unfortunately, with no parking brake, no good way to tie the aircraft down and an engine that won't consistently idle, I can't safely step out of my Long-EZ to make adjustments. It takes 2 people.
Old 11-13-2019, 12:05 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default engine off
I think I can see why you are struggling to get help. You should make these adjustments with the engine off, particularly with a pusher.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 11-13-2019, 04:14 PM
Absolutely, engine off when adjusting on a pusher. If you don?t know what adjustments to make, we can help with that.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Old 11-13-2019, 04:17 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Just call Don Rivera at AFP. The best answer you'll get will come straight from Don...and if he and Colleen ever decide to host another fuel injection class, I'll go again...I wish Don was allowed on VAF...
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
