  #11
Old 11-11-2019, 05:39 AM
Timberwolf Timberwolf is offline
That report states it was Not amateur built....curious if it?s a clerical error or something different
Shane
RV-6 IO-360 Angle valve, G3X touch
Murphy Moose M14P flying
Aero Engineer, A&P
Old 11-12-2019, 10:52 PM
mbauer mbauer is offline
Default Constant Speed Wood Prop?
Had to re-read it more than once, Throttle forward, Mixture and Prop controls back for engine shut-off.
Wood prop. Never seen a constant speed wood prop??? Typo?
Best regards,
Mike Bauer
Mike Bauer
N999SN 1998 Syd Nelson RV-6 (purchased 2017)
UTC -09:00 Alaska
Old 11-13-2019, 04:50 AM
fixnflyguy fixnflyguy is offline
Default The quadrant
The quadrant is the part that baffles me. Moderators took my comments out because I speculated (my bad, I apologize), so let me re-phrase. I know the plane he was in because I was going to ferry it home for Joe when he was buying it. I have pictures of the airplane inside and out (before the accident). I studied it since I was going to fly it. Fixed pitch wood prop, three lever quadrant. I don't know what the prop control was connected to if anything. I still pain over this accident because Joe was a friend.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 11-13-2019, 05:37 AM
F1R F1R is offline
[quote=fixnflyguy; Fixed pitch wood prop, three lever quadrant. I don't know what the prop control was connected to if anything. I still pain over this accident because Joe was a friend.[/QUOTE]
Normally a 3 lever quadrant with a carb and a fixed pitch prop has a throttle, mixture and carb heat lever.
Normally each of the 3 knobs or lever grips have a diiferent shape on them so they can be identified by feel.
However, even high time pilots can make a mistake of pulling the mixture instead of carb heat. Ask me how I know.
Or with gloves on, pulling mixture at the same time you only intended carb heat application.
Add a face mask that might block or restrict your view, low hours, and low airspeed.
It is never easy to loose a friend.
Very sorry for your loss.
