Originally Posted by tx_jayhawk
All,
I am curious as to what the rule is regarding adel clamps FWF. Are high-temp (white ones?) required FWF? I know Van's plans as well as about every RV I have seen has some regular black ones FWF, so what is the "rule" regarding the white ones?
Also, does anyone know the part number for the special white D-shaped clamps that are used on the valve covers to hold the spark plug wires?
Thanks for any help,
Scott
7A Finishing
BTW, you can get Adel clamps from McMaster Carr in both Black - Neopreme, and White - Silicone. Both can also be had in stainless bands.
Btw, there is one other huge advantage to the white ones beside the temp. They don't discolor whatever you put inside of them like the black ones do..
Also note you can get them in "wedge - WD" or non-wedge versions.
