11-01-2019, 11:01 AM
That?s what I was thinking Steve. The autopilot would control everything and just tell the pilot to advance or dial back the throttle to control the airspeed.
11-01-2019, 11:10 AM
A no autothrottle approach (AT) is often called a "CAT II Monitored" approach when coupled to an ILS.
Following the Glide Slope down the chute on an RNAV type approach is no big tech deal, and having the pilot control airspeed with the throttle is pretty simple too (in a two person crew the pilot monitoring would act as the AT). In a certified aircraft the Radio Alt is critical since GPS isn't accurate enough to determine the start of the flare. In a "Passive Fail" system with no rudder inputs from the AP, assuming you hit the runway and flare properly, the aircraft has no way to track the centerline on roll out (maybe not a big deal here).
So if you can develop an AP that will track Vertical Nav (VNAV) and the course (LNAV) you can fly a RNAV RNP type approach all the way to the flare... then some piloting may be required for the last few feet!
I don't know of any RNAV RNP type approaches that are currently certified for Auto Land in the certified world...
RV-7 Tipper
Bill (Wild) VA-165 '90-'93
Anacortes, Wa
Start 2/19 Emp complete 4/19 Wings complete 11/19 Fuse complete 6/20 Finish kit Complete 8/20 Electric/Avionics complete 9/20 Waiting on a motor...
Exempt x 3 - Donated 2020
11-01-2019, 11:17 AM
emergency landing system
You could just hook it up to your magnetos and the autopilot could fly with whatever throttle setting it has to a safe approach, cutting the mags when it has enough potential energy to make the runway or field.
Believe it or not, all aircraft used to run at full throttle, and cutting the "mags" was how the pilot reduced power.
11-01-2019, 12:29 PM
umm...
"...(in a two person crew the pilot monitoring would act as the AT)..."
Yeah, no...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
11-01-2019, 01:18 PM
Congrats to GARMIN
Great achievement!
AT is not required for Autoland. I can imagine some kind of graphics on the G3X screen commanding the passenger/remaining pilot to operate the throttle as required to keep the airplane flying, but I am sure Garmin has already solved this step. Fadec/AT on the Lycosaurus would be a nice addition and it's long overdue with today's technology.
My guess is that for a G3X system a yaw damper servo and a radio altimeter would be required to accomplish a successful autoland. +the button to activate it
EDIT: after reading the article I realized everything was mentioned there. I should read before writing
Igor
RV-10 in progress
Build Log
Reason: little more reading
11-01-2019, 01:30 PM
umm...
"...AT is not required for Autoland..."
Uh, if you don't have AT then it isn't an autoland because you are intervening...
Bob
RV-10
297 HP Barrett Hung
Wiring...
11-01-2019, 01:37 PM
Seems in addition to the 3-axis AP a throttle servo and a mag ground would be all that's needed for a safe automated landing.
May not be as sophisticated as the full solution they are offering with the announcement but it would be way better than the alternative.
Automated broadcast over CTAF or Tower and ADSB should widen the safety margins enough.
I'd install that.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
11-01-2019, 02:03 PM
Don't forget servos for the brakes. Otherwise the system would have no way of steering or stopping once on the runway.
All the media I've seen on this so far talks about autoland as a tool for emergency situations. Pilot incapacitation and the like. Can the system also be used just as an autoland by the pilot i.e. without the automated airport selection, without the automated radio calls and without the 'hey idiot watch this video or die' canned videos taking over the displays.
Joe
RV-12 Empennage
11-01-2019, 02:34 PM
Auto land
Technically feasible- absolutely
Economically practical for general aviation- maybe
Market demand if to be used only for emergencies - very little
Market demand if can be used for any landings - somewhat more than very little
Reduction in general aviation deaths - minimal (save about equal to that from ballistic parachutes but loose some that “hit the button” to land in a situation that should be avoided like bad weather and outside parameters envisioned for the auto land system)
Your opinion may differ.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
11-01-2019, 02:55 PM
For non-emergency use, the system clearly lacks the triple-redundancy built into cat III autopilots, so a rule change would be needed.
Since this system is designed for emergency use only, I think many of us are not too far away already - if the goal is saving lives, not the airplane. I run a Trio autopilot/GRT efis/G420W/SL30 ILS. I'm sure other avionics are equally capable. If I set up a coupled approach (ILS or LPV) at 70 kias/partial flaps, the system will fly the airplane onto the runway (nose first), likely breaking the nose gear, prop strike, possibly exiting off the side of the runway, maybe breaking the main gear if the airplane is in enough of a crab, etc. - but most likely survivable for passengers. "All" that's needed is to automate the initial set up (to something a passenger can do), and to set the throttle to an appropriate setting.
