DMAT,
I?ve just done about the same thing on my RV4. On the wingtips, I replaced the standard Whelen POS bulbs (bayonet style) with LED bulbs from aero-lites.com. It took approximately 5 minutes to do both wingtips. I used the NAV-Max bulbs listed on their website - $45 each. They have a less expensive option, but these ones are brighter, much more robust, and guaranteed not to make noise in your headset. For the tail, I installed the FlyLeds stand alone tail position/strobe ($140). I had a Whelen strobe mounted on the top of the tail, but it didn?t work anymore because of a failed power supply, so I removed that miniature dinosaur and patched the hole in the fiberglass tip. Good luck with your upgrade. It can be a simple thing sometimes.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
