Old 10-27-2019, 08:00 PM
pilot28906 pilot28906 is offline
Default GRT Pitch Servo Bracket Position
I am not installing the GRT servos at this time but have installed the wiring harness and ordered the pitch servo bracket to install. However, there are no instructions as to where/how to install it. I have searched the GRT web site and can not find any instructions. I see in some old threads where others have used True Track or Dynon instructions; is this still the case?
Also, is it wise to install the bracket now or just wait until I purchase the servo?
This would be for a 7.
John Johnson
Murphy, NC
RV7
Old 10-28-2019, 05:35 AM
carlrai's Avatar
carlrai carlrai is offline
Default Pitch Servo
Here's link to the TruTrak installation drawings. The TruTrak servo is same dimensions as the GRT. This should be all you need to install the bracket.
It would be best to have the servo in hand to do a final check on throws to insure no over center issues.
https://cdn.shopify.com/s/files/1/21...55619679118435
Carl Raichle
Lutz, FL
RV-9A N194CR
RV-14A Under construction
Based at KZPH
AA4SR
Old 10-28-2019, 12:06 PM
Thanks Carl!!
John Johnson
Murphy, NC
RV7
