Old 05-09-2007, 02:08 PM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Default Canadian who built w/o gascolator?
Any Canadian planes out there without gascolators? If so, how did you get by the MD-RA inspector? I have a performance airflow injection system and they are recommending not to use a gascolator.
Old 05-09-2007, 02:36 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Some inspectors are willing to listen to reason on this one, others are not. With high pressure EFI and return systems, the gascolator is of questionable value and probably a liability. Makes sense for a carb. Makes no sense for EFI or other high pressure FI with tank return lines.
Inspectors do want to see quick drains at all low points including header tanks. This makes sense in my mind.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 05-09-2007, 10:27 PM
mark manda's Avatar
mark manda mark manda is offline
i know a guy who just flew his "sold" hr-2 into canada for the new owner.
didn't pass-- 1. no gascolator. (had the fuel filter set up)
2. fresh air for cabin was drawn from behind the baffles. Not allowed; must draw fresh air from up in the inlet area.
FWIW
Old 05-10-2007, 12:37 AM
teaguy teaguy is offline
Just had my inspection within the last 30 days, I have airflow performance boost pump, I mentioned how I had read where gascolators not recommended with setup, red flags went up for my inspector, long story short I now have a gascolator.
Mark Mercier
RV-7A
Vancouver, BC
Old 05-10-2007, 04:30 AM
Tom Martin Tom Martin is offline
I have built seven planes in Canada, one RV4, two HRIIs and four F1s. There is nothing wrong with a gascolator for these installations. Lycoming engines have run reliably with gascolators for decades. Often when we thing of gascolators we have recollections of the old style units with the flimsy rod that swings down to capture the bowl. Van's sells a very nice slolid aluminium unit that is rated for 60psi and Andair sells a beautiful unit that has many nice features.
Gascoltors will not filter as well as some of the filters that come FI systems but at least you can sump the gascolator. This will not only give you an indication of water but also of other contamination issues. The filter systems that I have seen do not have this capability and I believe it to be important.
Fuel systems on experimental aircraft are the major source of accidents, be careful.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 05-10-2007, 02:13 PM
mgomez's Avatar
mgomez mgomez is offline
Default Question from a non-Canadian
I was looking at a new RV-7 recently, and noticed that the gascolator was not at the lowest point of the fuel system. Not in the 3-point attitude, and not in the level attitude either.
This isn't the fault of the builder...it's just the geometry of the RV-7. If it's going to fit inside the cowling, the fuel tanks will be lower than the gascolator.
So my question: is it still worth having a gascolator?
Martin
Martin Gomez
Redwood City, CA
"My RV-7 is a composite airplane: it's made of aluminum, blood, sweat, and money"
RV-7 Slider QB
Old 05-10-2007, 04:27 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Horse has been beat.
There has been debate on this for years on this list and others. I am a traditionalist (I'm addressing carbs only). The Gascolator has MORE volume to hold more water. Some want to depend on little in-line filters. I think that is a bad idea. The only saving grace is most RV's are pampered pets that live in hangers and rarely see rain. I think a gascolator is fine, and you are right it really is almost impossible to get it at the TRUE low point. However it is a big can to catch gunk.
You can have an "experimental fuel" system, but like primary structure, unless YOU REALLY know what you are doing, don't mess with it. If it ain't broke don't fix it. There have been a few cases of "clever" fuel designs that met with less than successful results, e.g., engine involuntarily stopped turning in flight, i.e., pucker factor 11.
Wisdom I was told and learned the hard way: Follow the plan's?
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
