Old 10-21-2019, 08:59 AM
Pilotjim77 Pilotjim77 is offline
Default Loose Intake Hose Clamps
I pulled the cowling yesterday while chasing some wires, and I found that three of the eight clamps on the intake hoses were pretty loose. Each intake hose has two different kinds of clamps; the inner clamps closest to the sump have wing type screws that you can turn with your fingers. The outer clamps have hex/slotted screws. Only the inner clamps with the wing screws have become loose.
I am thinking I should replace the wing screw clamps with hex type clamps. Seems like I could tighten them down quite a bit more. Maybe that's why they are coming loose? Any thoughts?
Thanks in advance!
Jim
Jim
Purchased July 2019: RV-6 0320 Whirlwind Ground Adjustable Prop
"We can porpoises?" -- Leo Farnsworth
Old 10-21-2019, 09:32 AM
Discus2b Discus2b is offline
?Wing? style hose clamps take a slotted tool driver bit to tighten beyond finger tight. They will stay tight. With good access, pliers work. Not a normally used clamp. My ?56 182 has some.
R
Old 10-21-2019, 10:14 AM
koupster's Avatar
koupster koupster is offline
I made a tool to tighten these clamps some tears ago out of a piece of steel tubing. The tubing was heated, one end nearly flattened to fit the clamp, and the other was squared to fit a 3/8" extension.
Cheers, David
RV-6A A&P
Old 10-21-2019, 10:24 AM
I replaced all of my clamps with the smooth T-Bolt clamps. I hope they do a better job than the old wing clamps.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 10-21-2019, 11:11 AM
rvbuilder2002's Avatar
The problem is that the hoses are always shrinking.... so what ever traditional clamp you installed will keep getting loose because of the hose shrinkage. It is not because the clamps are loosening.
Constant tension spring clamps are the way to go.
If you upgrade to the SDS intake kit
You get spring clamps with it.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 10-21-2019, 11:16 AM
Bicyclops Bicyclops is offline
Over torquing is to be avoided as it causes "cold flow" of the hose, a permanent deformation of the hose. It also damages the clamp. The table of limits in the Lycoming overhaul manual specifies the torque for worm drive clamps.
Ed Holyoke
Old 10-21-2019, 01:36 PM
D Weisgerber's Avatar
D Weisgerber D Weisgerber is offline
I I update to an SDS kit does it come with 8 clamps?
Dave Weisgerber
RV8 N848DW. Ser#83830 done.
James Cowl
DAR inspection on 7-23-2021
First flight on 7-25-2021
Phase 2 on 9-3-2021
Old 10-21-2019, 02:14 PM
Toobuilder's Avatar
Yes. Everything you need. Install and forget.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 10-22-2019, 06:43 AM
Red Mtn flyer Red Mtn flyer is offline
AND you get the benefit of actual seals at the intake, replacing those ^&*(% paper failures... which is what the kit is about.
Ben K.
A&P; RLSA - A,G,W/S Falco F-8L
50 yrs of flight and counting
Dues paid 2017 thru 2020
Old 10-22-2019, 08:14 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Thanks in advance!
Jim
Not sure what you're actually using, but a general purpose stainless steel worm-drive hose clamp does fine. They will likely loosen a little over time. Just check them every 100 hours or so. 1/4 or 1/2 turn of the screw to snug them up. Or, spend a chunk of money and not worry about checking.
Bryan
Houston
