Actually the green light should just come on at No. 1 cylinder top dead center. The 25 degree nominal advance is built into the unit. The check with a timing light is a first time confirmation of proper operation and should indicate at idle as below:
From the manual:
Engines Normally Timed at 25 degrees BTDC -These are usually engines with compression ratios less than 8.7:1.
- At idle the timing display should indicate 40 deg ? 2 deg when the manifold pressure hose is connected and 21 deg ? 2deg when disconnected.
Dave Gehle, P.E.
Fayetteville, Arkansas KFYV
RV-4 (sold), RV-6A, J3-C65 (sold)
