Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 10-10-2019, 03:42 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post Garmin GDL 82 V2.01 Software, Oct. 10, 2019
Hello GDL 82 Users,
As some of you are aware, the initial GDL 82 software could transmit a couple of "uncloaked" ADS-B Out messages with real aircraft ICAO address and Flight ID on power-up, even with the transponder code set to 1200 and the Anonymous switch active.
Many of you requested this be improved, and we are happy to report that this work is complete. The new V2.01 software includes improvements to make sure that a system starting up with the Anonymous mode switch active and a transponder code of 1200 will enter Anonymous before transmitting any messages thus safeguarding the true ICAO address and Flight ID of the aircraft.
We also created a special non-certified aircraft service bulletin with instructions on using the same PC installation tool and USB interface you originally used to install/configure the system to install the new software.
The service bulletin and V2.01 software can be downloaded from the GDL 82 Software Download page. There is one download for the software plus service bulletin, and a second for the PC tool if you need it. The PC tool is unchanged.
Let us know if you have questions.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 10-10-2019, 04:14 PM
DanH's Avatar
DanH DanH is offline
May I be the first to send a "Thank you" to the entire Garmin team? It was the right thing to do, and ya'll got 'er done.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-10-2019, 07:34 PM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
Is this update applicable to certified installations?
Jerry Esquenazi
RV-8 N84JE
Old 10-10-2019, 08:01 PM
g3xpert's Avatar
Post
Hello Jerry,
Yes, the same software is used for all installations, but there is a separate service bulletin for certified aircraft.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 10-11-2019, 06:48 AM
GWZ GWZ is offline
I?m planning an update and the GDL-82 just went to the top of the list. THANK YOU!
Gunther
2002 RV-9A 150hp
Old 10-12-2019, 11:52 AM
larryj larryj is offline
A big giant THANK YOU from me also. Way to go Garmin !!!!
Question:
In planning a new panel from (almost) scratch; in order to have the anonymous mode would I need to use the GDL-82 with a non-ADSB xponder or can we expect similar software upgrades for the GTX-345 etc. ??? In other words, how would I get anonymous ADSB in/out with a G3X based system ???
Larry E. James
Bellevue, WA
Husky A1-C
Rocket (under construction)
Old 10-12-2019, 12:19 PM
g3xpert's Avatar
Post
Question:
Hello Larry,
You are welcome.
Currently, the only way to operate in anonymous mode is with a UAT Out solution like the GDL 82 with a GTX 325 or GTX 327 Mode C transponder. We support the GTX 325/327 transponder connected to a G3X/G3X Touch system including touch screen control if you wanted to go that route. You could add a GDL 50R or GDL 52R for ADS-B In traffic and weather.
Perhaps some day we will be allowed to support Anonymous mode on a Mode S ADS-B Out transponder like the GTX 35R/45R/345/345R, but that is not currently permitted.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 10-12-2019, 12:42 PM
scsmith scsmith is offline
What I appreciate most is that a large company like Garmin would provide a super-knowledgeable support person to keep a community like VAF well-informed, answer questions, listen to concerns.
How many companies do you feel like you have a direct interface to the technical staff?
Thank you!
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet" Flying since Sept. 2009
Hobbs 700
also
1/4 share in 1959 C-182B (tow plane)
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Dec 2021
Old 10-12-2019, 02:52 PM
RV8Squaz's Avatar
Originally Posted by g3xpert View Post
Hello Jerry,
Steve
Thank you very much Steve!
Jerry Esquenazi
RV-8 N84JE
Old 10-16-2019, 07:56 PM
A2Jake's Avatar
A2Jake A2Jake is offline
Default Garmin GDL 82 V2.01 Software, Oct. 10, 2019
Hello GDL 82 Users,
Steve
This is the deciding factor that confirmed my decision to pull the trigger the next day for the 82.
Was not convinced it was right for me and was sitting on the fence but this gave me that warm fuzzy feeling that now it is what it should be , installing now.
J.
RV-8 Project Rebuild ( flying 4-2-2019 )
RV-8 Fastback New build in progress
Aeronca L16 Champ
Cessna 195
