Old 05-07-2007, 08:15 PM
N941WR's Avatar
N941WR N941WR is offline
Default What size adel clamps?
I need to know what size adel clamps are used
A. On the engine mount?
- 11's are to small and some 12's are to big.
B. To go around the SCAT tubing used for the cabin heat?
- Just trying to isolate things so they don't move around in flight.
Thanks for the help.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-07-2007, 08:18 PM
Radomir's Avatar
Radomir Radomir is offline
For B see cabin heat drawing (FWF) -- they have you use a small strip of stainless steel to wrap around the scat tubing.. but I guess lacing cord would work there too?
Radomir
RV-7A sold
Old 05-08-2007, 04:01 AM
Kevin Horton's Avatar
Most of the engine mount tubes should be 3/4" dia, which should fit a -12 Adel clamp. The tube that runs left to right behind the engine might be larger diameter - it is 7/8" on my RV-8 (-14 Adel clamp). If you've got a clamp that is a bit loose, you could wrap a few turns of electrical tape around the mount first to increase the diameter a bit.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 05-08-2007, 04:09 PM
GAHco's Avatar
GAHco GAHco is offline
Default Clamp info
This may help you.
We even stock some clamps that have 1/4" mounting holes, if you need them.
go to http://www.gen-aircraft-hardware.com/
On the menu on the left go to "Clamps"
expand that and see more choices.
The little wrenches will get you PDF's of the ones that are identified either to the left of the Wrench or above it.
The Text in the menu's will either take you deeper into the selections or into the sales portion of the store.
Hope this helps.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 05-09-2007, 05:05 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Bill on thing that will help is knowing how the adels are numbered. Adels are in 1/16th inch increments. so a #16 is a 1"
If you have a 2" scat, it will be a #32. Your engine mount will be 12's, and so forth.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 05-09-2007, 09:34 AM
gasman gasman is offline
Default LACING CORD
Lacing cord won't wear out the scat tubing like an adel clamp or a ss strap.
Look for "KOROSEAL LACING"
