Old 10-08-2019, 08:53 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Default Mcfarlane throttle cable for RV-7A Lycoming IO-360M1B
Has anybody used a McFarlane 'Vernier-Assist' throttle cable on an RV-7A with a Lycoming IO-360M1B (specifically this engine on this aircraft)?
If so, which model number did you use?
The Van's stock cable is the 50.5 inch cable, but McFarlane's website doesn't advertise such a length. I'm trying do determine the correct part number.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
Old 10-08-2019, 11:41 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is online now
Sid,
Download their catalog and look at page 34. I'm looking at the catalog I picked up from them at OSH this year. The V.A. throttle control with 10-32 threaded end is MCTV1035-LLL (LLL= length in inches) or MCTV2035-LLL with 1/4-28 threaded end.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 10-09-2019, 06:18 AM
scrollF4's Avatar
That's the one, Carlos, thanks. Will call them today. Maybe I can receive and install it before the Pine Bluff formation clinic. I'm on my 2nd Van's stock cable, but it just isn't smooth. I've tried heat shield, rerouting for a straighter cable path...it still tries to bind up, making precision power adjustments difficult while flying in formation. My bro-in-law's new-to-him 7A as this McFarlane throttle cable: It is VERY smooth, precisely what I need for good formation work.
Thanks again, Carlos.
Scroll
Exemption waived.
Old 10-09-2019, 07:10 AM
Walt's Avatar
Walt Walt is offline
Be prepared for sticker shock on a custom length...
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 10-09-2019, 07:38 AM
scrollF4's Avatar
Yep, I know, but the stock push-pull cable isn't hacking it.
Scroll
Exemption waived.
