Old 10-07-2019, 08:03 AM
GPV GPV is offline
Default Squeezer smilies
Hi all,
I clearly can't hold a squeezer straight to save myself and get quite lot of these smilies around round head rivets...hope the link works...
https://www.instagram.com/p/B3UXAkwh...=1wzqggami6met
I'm not sure whether they are only in the primer or affect the aluminium as well (primer is way too thick so they possibly didn't get all the way through). I can't see any shiny metal at the bottom of any of them but I guess the only way to be sure is to sand it back to see if the aluminium is damaged and go from there. Any thoughts anyone, should I bother?
Greg
Old 10-07-2019, 09:39 AM
John Tierney John Tierney is offline
I help out at the sheet metal workshop at Airventure, and it is always eye opening to people that have never riveted before that using the gun results in better rivets than the squeezer. Make sure you are only moving one handle on the squeezer. The handle that is in-line with rivet shaft should not move. Don't get your shoulder and upper body involved in the squeeze, which is hard with 1/8" rivets. If possible, put the squeezer yoke in a vice and move the work piece to it.
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 10-07-2019, 09:56 AM
wirejock's Avatar
wirejock wirejock is offline
Default Gorilla tape
Buy a roll of black gorilla tape. Use a small piece to protect the part. 1" section is good for 4 rivets.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 10-07-2019, 10:00 AM
PilotjohnS PilotjohnS is offline
Default double squeze
Also, on the -4s I typically double squeeze the rivet. I find it nearly impossible to get a good rivet squeezed if I try and rivet with only one squeeze.
Make sure the rivet set is not moving in the squeezer; have the part in a clamp so it cant move either. You should be able to maintain the squeezer square to the part for the entire pull, otherwise the forces are so great, things will move around, especially if the holes are not perfect to begin with. a buggered hole is why a reworked rivet almost always comes out worse than the original.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2021, worth every penny
RV9A- Status:
95% done, 10% left to go
Electrical/Panel done
Firewall Forward 75%done
Fiberglass 0%, thought i was building in metal?
www.pilotjohnsrv9.blogspot.com
Old 10-07-2019, 10:18 AM
MED MED is offline
Depending on upper body/arm strength, you may reach a point in rivet size where a pneumatic squeezer is easier to manage consistently. Borrow a buddy?s and try it, then decide if you need one. You can get most of your investment back by selling it when you are flying.
MED
140236
N435MD
Miss March 2020
Old 10-07-2019, 10:41 AM
tomkk's Avatar
tomkk tomkk is offline
The quality of my squeezed rivets improved dramatically after I sprung for a Cleveland Tools Main Squeeze. I found I had to apply so much force to a conventional single stage squeezer (for lack of a better term) that I couldn't hold the squeezer lined up well and square to the work piece. The Main Squeeze fixed that ...
Tom
Port Orange, Fl
EAA #51411
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 700 hrs as of 02/2020
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK; First Flight 03/13/2020
Old 10-07-2019, 11:15 AM
nilberg nilberg is offline
I found out when I was building the Empennage (first time big shake squeezing with pneumatic tool), that I got better result have the part sticking out of the workbench and let the yoke ‘hang’ on the rivet. Then I could use all my strength and coordination on keeping the squeezer straight.
I did develop a feel for ‘tool straightness’ and was soon able to squeeze consistently at all angles.
Bjorn N - RV 7 in progress
Katy, TX
https://eaabuilderslog.org?s=N64BN
Old 10-07-2019, 01:12 PM
sf3543 sf3543 is offline
Is it possible you are using the wrong die?
For example using the squeezer die for a #4 rivet on a #3 rivet would likely do that.
Just a thought.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
Legend Cub
Old 10-07-2019, 02:30 PM
TASEsq TASEsq is offline
Are you using a pneumatic squeezer here?
If so, two things I found helped. Make sure the yoke is tight in the squeezer with no movement when it squeezes (tighten the nuts). Second, I get my head down and make sure the amount of air gap around the set is equal - then it has to be square on the rivet. Make sure you are not tilting the body of the squeezer when you are pushing the trigger.
+1 for making sure you have the right size. A -4 set on a -3 rivet will make a smiley for sure.
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
Old 10-07-2019, 05:25 PM
GPV GPV is offline
Thanks for the tips and responses everyone. I need to go practice.
To answer your questions, yes the die was definitely correct and the squeezer is pneumatic. I was probably just lining it up incorrectly and my holes may be off a bit too. A fair few of my rivets were crooked so it wouldn't surprise me. Gonna have to go practice. Will definitely try some tape to protect things next time too.
Do I need to do anything to repair these things like sand them out?
