  #11
Old 05-09-2007, 07:30 AM
WSBuilder WSBuilder is offline
Default Mushroomed Steel
My C-frame held up well, also. But I sure peaned the top of the set rod! It sure wouldn't fit a rivet gun throat without grinding it smooth again. I used a 4-pound hammer, mainly because the strike surface diameter was bigger. Now I can't get my right forearm in my shirts, while the left has plenty of room.
Bill Grant, A&P
8KCAB, M20G
RV-4: Fuselage controls
Old 05-09-2007, 08:09 AM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
" Insert Tool Time grunt here..."
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 05-09-2007, 03:12 PM
penguin penguin is offline
I used a 3x rivet gun to build my spars, but had a very short and very heavy (30lb?) C frame to keep everything aligned. I tried the 4lb hammer routine first, but found that the 3x, turned up full, did the best job.
Pete
