Old 09-29-2019, 07:19 PM
jselvatici's Avatar
jselvatici jselvatici is offline
Default Help to order the proper Cowl Air Scoop
VAF Folks,
I'm trying to identify the correct part number for the lower cowl air scoop to be able to order it for installation on a RV-9A.
Doing some search, I see how people install it and so on, but not really the number for that part to order at Vans. Even at Vans, I didn't see it.
Maybe I'm looking on the wrong place on Vans store? (https://shop.vansaircraft.com/cgi-bi...=cowl-airscoop)
Appreciate the experienced people's help.
Thank you.
Juliano Selvatici
RV-9A / N349RV
1st Flight on 8/14/2020
O-320 + 3 Blade Catto Prop + Steam Gauges (yes!)
A&P / Private Pilot
RC Pilot ( if that counts )
2019/2020 VAF Contribution Sent
Old 09-30-2019, 02:43 AM
rvbuilder2002's Avatar
The scoop is a molded part of the lower cowl, so you order the lower cowl that matches the configuration of your engine.
I think the finish kit order form (where people generally order the cowl) has info regarding making the proper choice.
Scott McDaniels
Hubbard, Oregon
Old 09-30-2019, 09:28 AM
jselvatici's Avatar
Default Have an older lower cowl
Thanks for the reply. Point is I have an older cowl that didn't came with the scoop, thus I need to install it on my lower cowl.
I wish it had a scoop already installed.
Juliano Selvatici
RV-9A / N349RV
A&P / Private Pilot
