Old 09-26-2019, 09:49 PM
FlyGuy65 FlyGuy65 is offline
Just bought the Rikon 10-305 and a 24tpi blade. Used it on the AB4 187 stock (3/16 thick). So far it's just what I needed. Only drawback is the slot in the table is a non standard size, so most miter guides won't fit. Easy enough to make one for 90 degree cuts, but just ordered the Rikon one for angled cuts (though the reviews weren't very good for the mitre).
I'm new to band saws, but first cuts have come out decent. Used WD40 as cutting fluid. Needed some cleaning up of the cuts, but far quicker and nicer than hacksaw.
Edit: Mitre came today.Very happy with it. Fits snug in the slot, looks like it will do everything I will need.
Old 09-27-2019, 06:23 AM
tyconnell's Avatar
tyconnell tyconnell is offline
Probably due to my lack of skill, the bandsaw is a "rough cut" tool, taking off most of the material (be it wood or metal). From there, depending upon size, a belt sander, Scotch brite wheel or Dremel attachment is generally the next step.
Ty Connell
ty.connell@gmail.com
Donated 2020
Old 09-27-2019, 12:25 PM
rapid_ascent rapid_ascent is offline
The nature of a bandsaw cut is not going to clean enough edge for me. I use it to cut it to the line and then sand on the 1? sander to final dimension. I?d say 95% of the cuts are 3/4? angle. Some times there are some larger pieces but it?s pretty rare.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 09-27-2019, 06:44 PM
DaveWelch DaveWelch is offline
Default Cheap Band Saw
I got by with the 100 saw, but if building another plane, or anything that I want good quality result, I?ll get a better band saw. The cheap one cannot cut a straight line, always a few degrees off. No amount of adjustment improves it. Means you must allow for that and then sand or grind or file away a lot of material to get a good looking piece.
2-cents...
Dave
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
