Old 09-22-2019, 08:25 PM
Zazoos Zazoos is offline
Default Aileron and Wing tip alignment
All my rigging is done and everything is within specs. YEAH!!!
My right wing tip is a bit high compared to the aileron.
I was thinking of two approaches to fix it.
First is to remove the rib at the tail end and then take my heat gun to it. If it moves enough to align then rivet the rib back in.
Second option is remove the rib at the tail end, cut along the dotted line in the picture below, shape it, and then glass it back together.
Which way would you go or have an alternate approach in mind?
Thank you,
Trent Flemming
Marshall, TX
Building Zenith 750 Super Duty
RV6 - N86TF
SunDog Powered Parachute - N75372
Dues Paid 11/2021
Old 09-22-2019, 08:29 PM
Most people seem to have solved this problem by splitting the tip's trailing edge, aligning it, the re-gluing it. You'd have to de-rivet the rib for that to work and you'd have to change the rivet spacing when you re-attach it to keep the tip aligned. I'd suggest using the current holes on top and drilling new ones on bottom.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-22-2019, 08:37 PM
Kyle,
That sounds like a much better solution.
Thank you very much.
Trent Flemming
Marshall, TX
RV6 - N86TF
Dues Paid 11/2021
Old 09-23-2019, 08:40 AM
Janekom's Avatar
Janekom Janekom is offline
Splitting at the trailing edge works well. Then you can work on the length of the tip as well. As in make it shorter or extend it a bit.
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2021 WITH A SMILE
Old 09-23-2019, 06:28 PM
RV6_flyer's Avatar
What Kyle said.
I also had to cut mine on the seam up the outboard side to get mine to align correctly. One side, I had to remove almost 1/4" of material on the outside seam.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-24-2019, 08:15 AM
Dugaru's Avatar
Dugaru Dugaru is offline
Default Wing tip / aileron mismatch
Both of mine are mismatched a bit. I can confirm that leaving it as is has no apparent effect on flight characteristics.
N929JA, 2007 RV-9A
Based W96: New Kent International Aerodrome
(near Richmond, VA USA)
2021 Dues Paid
Old 09-24-2019, 09:40 AM
edbooth edbooth is offline
I have built four RVs, and have always lined up the flaps, ailerons and wing tip while still in the wing cradle, before drilling the tip. Always came out great.
