Old 09-22-2019, 06:25 PM
BH1166 BH1166 is offline
Default Crankshaft Seal Part Number O-320 D1A
Could someone confirm this is the Lycoming part number I need for a Lycoming O-320 D1A 160hp = LW-13792. Seems to many options, over size, under size, split, no split....I am a bit confused and plan to drive to AS and pickup needed part and Dow adhesive tomorrow. Thanks
Butch
RV6A Purchased N72TX
2020 Dues Paid
Old 09-23-2019, 07:00 AM
chaskuss chaskuss is offline
That is the correct part number. There is also an oversized version of this seal. It is part number LW-13792-P50. The oversized seal would only be used in the event that the crankcase has had to be machined 50 thousands of an inch larger in the seal bore, of the crankcases.
Charlie
Old 09-23-2019, 11:10 AM
Thanks Charlie
Butch
2020 Dues Paid
Old 09-23-2019, 11:15 AM
Default Useful thread
Butch,
Check out the thread below for tips on replacing that oil seal.
http://www.vansairforce.com/communit...rankshaft+seal
Charlie
